Larry D 0 #1 Posted September 27, 2023 Does anyone know if the mower deck spindles are the same on a Series 200 36 inch RD and a 37 inch SD? Share this post Link to post Share on other sites
ri702bill 10,808 #2 Posted September 27, 2023 Larry - welcome. Download the manual for each - look over the part numbers to get your answer. There are FOUR possibilities for innards, although the decks accept all as a complete replacement (some blade interfaces are different though). 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #3 Posted September 28, 2023 Not likely. The 36" deck is a 3-spindle deck... the 37" has only two spindles. They are not even similar.  1 Share this post Link to post Share on other sites
peter lena 9,596 #4 Posted September 28, 2023 @Larry D looking right at you , ? notice the opportunity ? WIDE RUBBER BEARING , GREASE SHIELDS ? no matter what the spindle, hi temp / hi stress , re / grease . just a suggestion , Pete Share this post Link to post Share on other sites
8ntruck 8,397 #5 Posted September 29, 2023 The local furniture store is also as Cub Cadet dealer. On our last visit three, I noticed a Cub Cadet display bragging about their tool free blade changing system. It is a spring loaded bayonet type system. Push the retainer back against a spring, lift the blade off of the drive lugs, turn it 90 degrees or so, then it comes off of the spindle. Kind of neat. My next thoughts were about adapting those spindle assemblies to Horse decks, to get currently supported parts into an old deck. Share this post Link to post Share on other sites
Larry D 0 #6 Posted September 30, 2023 (edited) On 9/28/2023 at 8:56 AM, peter lena said: @Larry D looking right at you , ? notice the opportunity ? WIDE RUBBER BEARING , GREASE SHIELDS ? no matter what the spindle, hi temp / hi stress , re / grease . just a suggestion , Pete I found out once I got there that they were not the same. I still need new spindles for the 0536MR03 deck. Where can I get them? I am quite confused with your response. Partstree shows them as 107448 but I also saw the complete unit as 105074 Edited September 30, 2023 by Larry D More info Share this post Link to post Share on other sites
peter lena 9,596 #7 Posted September 30, 2023 @LarryD sorry larry, our views and spindle experience , is on opposed ends of the scale, no sarcasm / insult intended . done decks , the opportunity , to replace , original grease , at that point, is what's done to prevent , inevitable failure , thats how I see it . you are looking at the entire spindle , main thing I see , is the WIDE BLACK RUBBER SIDE SHIELDS , realize , you think a bearing is a bearing , lubricant failure due to , heat / stress , is what makes bearings whine with noise. they are literally telling you that . very often refer to next step , TO IMPROVE / CHANGE a failure point . thats how I look at at a problem , obviousely , PARTSTREE, is selling the correct bearing match , but it will not stand up , the first , rotational , hi heat , struggle it has , will change its sound / failure , my thought is why not prevent that ? probably best for you to just go with what's listed , stopping confusion . stay with the replacement , as is required, keep it simple , pete Share this post Link to post Share on other sites
Larry D 0 #8 Posted October 4, 2023 Would sure like to find someone with good used spindles for the 36 inch rear discharge mower 0536MR03. WH part #105074 marked discontinued everywhere that I have looked. Share this post Link to post Share on other sites
Larry D 0 #9 Posted October 4, 2023 (edited) On 9/28/2023 at 3:31 AM, daveoman1966 said: Not likely. The 36" deck is a 3-spindle deck... the 37" has only two spindles. They are not even similar.  Edited October 4, 2023 by Larry D Share this post Link to post Share on other sites
Larry D 0 #10 Posted October 4, 2023 The bottom assembly appears to be a match to what I need. Available? Share this post Link to post Share on other sites
daveoman1966 3,881 #11 Posted October 4, 2023 I don't have any and was just showing the difference of 36 & 37" decks. The COMPLETE spindle assy (ITEM 16) for 05-36MR03 is part # 109964. Share this post Link to post Share on other sites
Larry D 0 #12 Posted October 4, 2023 Thank you! I have found where to purchase these. Share this post Link to post Share on other sites
