moe1965 774 #1 Posted September 12, 2023 This is a new to me tractor that I received in a two package deal. I'm more into the older models so this hitch is new to me. It's on a 1990 toro wheel horse classic 312-8. Is it used to raise and w lower attachments in the back. I'm not quite understanding the three slots cut out. Just curious and always wanted to learn. Thanks Share this post Link to post Share on other sites
squonk 45,631 #2 Posted September 12, 2023 The slots are for a chain you would hook to a tiller to lift it. Share this post Link to post Share on other sites
lynnmor 8,651 #3 Posted September 12, 2023 Other attachments may need the slots as well, see this thread for some information Share this post Link to post Share on other sites
Handy Don 16,022 #4 Posted September 13, 2023 Use the lower slot for lighter implement that or one that needs a lot of movement to lift--the upper for heavier or less movement. This is called a rock shaft and it gives an adjustable-length chain a wider angle to extend directly back to the implement (sleeve hitch, slot hitch, tiller, etc.) while letting the cable to the mid-tractor lift mechanism remain straight and fixed length. 1 Share this post Link to post Share on other sites
