JimmyJam 542 #1 Posted September 9, 2023 So I have a 1968 Electro12. I would like to add a mower deck. Apparently I need a Speed Hitch #85211 (No Longer Available). I don't even know what that looks like. Option #2: I have extra Attach-Amatic parts and mule drive. Question: Could I make that work?? 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #2 Posted September 9, 2023 2 Share this post Link to post Share on other sites
squonk 44,650 #3 Posted September 9, 2023 The mid Tach o Matic will work. You will need an adapter to use the mule drive set up. I did these to my 67 1267 and can run the newer deck and snow blower on it, 2 1 Share this post Link to post Share on other sites
kpinnc 15,726 #4 Posted September 9, 2023 (edited) 4 hours ago, JimmyJam said: So I have a 1968 Electro12. I would like to add a mower deck. If you add the belly hitch, front hitch adapter, and the "T" lift found on everything after the early seventies- you can carry just about any "newer" mower deck on that machine. 36 side or rear discharge, 42 side or rear discharge, and the 48. All will work. Edited September 9, 2023 by kpinnc 2 Share this post Link to post Share on other sites
squonk 44,650 #5 Posted September 9, 2023 5 minutes ago, kpinnc said: If you add the belly hitch, front hitch adapter, and the "T" lift found on everything after the early seventies- you can carry just about any "newer" mower deck on that machine. 36 side or rear discharge, 42 side or rear discharge, and the 48. All will work. My 67 did not have the holes in the frame for the "T" bar. What I did was drill one hole in the deck and connect a chain from the deck to the rock shaft 2 Share this post Link to post Share on other sites
daveoman1966 3,877 #6 Posted September 9, 2023 6 hours ago, JimmyJam said: So I have a 1968 Electro12. I would like to add a mower deck. Apparently I need a Speed Hitch #85211 (No Longer I've made a free DOWNLOAD file named UPGRADE.pdf. It'll show you what to do to 'upgrade' the Electro 12 to accept the 'Tach-o-Matic implements.... with ease. This method eliminates the awkward SIDE belt drive... changing that to FRONT belt drive as is used from 1973 and newer model tractors. With this, most ANY mower deck can be used. This pic is a Raider 10 with the UPGRADE...from a few years ago. MULE DRIVE UPGRADE.pdf 3 1 Share this post Link to post Share on other sites
