GAJoe 852 #1 Posted July 23, 2023 I access to borrow a photo tachometer. I tried once on the K341 and put a piece of white hack saw blade under one of the screen retaining screws. I got crazy readings. I'm thinking that I need a larger target but I don't want to reduce the amount of cooling air flow. Where do you have success? Share this post Link to post Share on other sites
kpinnc 17,150 #2 Posted July 23, 2023 I put mine on the farthest outer side of the flywheel screen. May not stick for long, but it helps with setting the throttle at least. Share this post Link to post Share on other sites
oliver2-44 11,213 #3 Posted July 23, 2023 (edited) Actually might need a smaller target with a solid background. I suspect the screen holes may have driven it crazy. I have a tach like that and it came with 1/4" wide tape that you cut a small length off. I put a piece on the side of the larger PTO pulley and it works great. Edited July 23, 2023 by oliver2-44 2 1 Share this post Link to post Share on other sites
Handy Don 15,940 #4 Posted July 23, 2023 36 minutes ago, GAJoe said: I access to borrow a photo tachometer. I tried once on the K341 and put a piece of white hack saw blade under one of the screen retaining screws. I got crazy readings. I'm thinking that I need a larger target but I don't want to reduce the amount of cooling air flow. Where do you have success? Depending on the tach, it may simply need a contrasting color stripe. I’ve painted them onto the visible rotating parts on the PTO side of my tractors. 1 Share this post Link to post Share on other sites
lynnmor 8,623 #5 Posted July 23, 2023 I use white paint or white-out, no need for fancy tape. 1 Share this post Link to post Share on other sites
ri702bill 11,256 #6 Posted July 23, 2023 I put the tape on the flat cylindrical surface ot the PTO bell. To get a consistant reading, you need to use the tach when out of direct sunlight.... Share this post Link to post Share on other sites
Racinbob 12,765 #7 Posted July 23, 2023 I put a piece on the flywheel screen and it works great. Not that it really matters but this picture was taken four years ago and I just checked. It's still there. Share this post Link to post Share on other sites
hotajax 230 #8 Posted July 23, 2023 Clean spot on the intake screen. The screen air passes through to cool the engine. It works. Share this post Link to post Share on other sites
