Gerry w 2 #1 Posted August 11, 2009 Hi, how do you adjust/free up, the clutch on a D200 that doesn't seem to disengage? I've tried to lengthen and shorten the control bar with no results. Any help would be appreciated. Share this post Link to post Share on other sites
Jim_M 179 #2 Posted August 11, 2009 Make sure the bearings aren't locked up. If you can see the plates seperate but the clutch still won't release you may have bad bearings. Share this post Link to post Share on other sites
Gerry w 2 #3 Posted August 11, 2009 Thanks Jim, The plates won't seperate at all, any way to loosen them?? thank you for your reply Share this post Link to post Share on other sites
pfrederi 19,936 #4 Posted August 11, 2009 I believe the owners manual tells you to service the PTO every 100 hours. Probably a good time to do that. Most likely something has gotten stuck from some corrosion or lack of lube. Share this post Link to post Share on other sites
Gerry w 2 #5 Posted August 11, 2009 I believe the owners manual tells you to service the PTO every 100 hours. Probably a good time to do that. Most likely something has gotten stuck from some corrosion or lack of lube. I just got it last week, no owners manual with it, did just take it apart, PB blasted it, what lube do you use?? All parts move good when belt/pulleys arn't attached, put them back on however.... thanks for the info and reply... Share this post Link to post Share on other sites
pfrederi 19,936 #6 Posted August 12, 2009 You have to remove the spiral lock rings (first ones I ever came across) to disassemble and there are two bearings inside (ball bearings if I recall) that need to be greased. PB Blaster doesn't make a good lubricant so I wouldn't try running it alot until you get it opened up cleaned and greased as one bearing costs $83 the other $50. Share this post Link to post Share on other sites
Gerry w 2 #7 Posted August 12, 2009 You have to remove the spiral lock rings (first ones I ever came across) to disassemble and there are two bearings inside (ball bearings if I recall) that need to be greased. PB Blaster doesn't make a good lubricant so I wouldn't try running it alot until you get it opened up cleaned and greased as one bearing costs $83 the other $50. one bearing costs $83 the other $50...........Whoa! That's salty! Any grease, will axle grease work? I was wondering about graphite lube or something. Seems to move well now, just won't stop spinning, someone told me in a PM that I need to place a load on it to stop it??? that it will spin if nothing is hooked up. Have you found that to be true? And thank you so much for the info, I'd hate to burn a bearing at that cost. Thanks again, Gerry Share this post Link to post Share on other sites
pfrederi 19,936 #8 Posted August 12, 2009 There is a brake pad mounted on the the bottom (similar to the C series PTO brake) Probably need to be adjusted. Don't recall the spec off hand but they are close to teh C series. I just used grease Share this post Link to post Share on other sites
Gerry w 2 #9 Posted August 12, 2009 Okay, thanks again, Im going to take it apart again tomorrow, got busy with firewood today <_< Thanks again for all the info, any feelings toward an electric over a manual clutch?? I have one I could replace this one with if it's a good idea. Thanks again, Gerry :thumbs2: Share this post Link to post Share on other sites
Jim_M 179 #10 Posted August 13, 2009 If the manual clutch is working good I would leave it on. The electric clutch may not handle the load of running a 48" snowblower or tiller on a 20 horse twin Kohler. Share this post Link to post Share on other sites
Gerry w 2 #11 Posted August 13, 2009 Thanks again, Now all I need to do is find that snow blower! I'll list the electric clutch then, thanks for the info. :thumbs2: Share this post Link to post Share on other sites
