BMW1 44 #1 Posted July 6, 2023 I am putting a Johnson Model 10 Midget Loader on a D200. I am using a 5-7 GPM pump. The pump indicates 7/8-14 for the pump ports. How big should the inside diameter of the suction hose be - line from hydraulic reservoir to pump? Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #2 Posted July 6, 2023 They are always bigger than the pressure lines and larger the better. 1 Share this post Link to post Share on other sites
Handy Don 16,022 #3 Posted July 7, 2023 @wallfish? I’d say 1” and be sure to use 2-wire hose (not as flexible but it’ll resist collapse) and suitable fittings. Share this post Link to post Share on other sites
c-series don 11,502 #4 Posted July 7, 2023 After seeing @Handy Don’s hydraulic work and fabrication skills at the Big Show I’d definitely trust his advice! 1 Share this post Link to post Share on other sites
wallfish 19,400 #5 Posted July 7, 2023 Yes, you always want the intake larger so the pump doesn't need to pull pressure in. Here's an old thread on one. You can see the intake hose is bigger Share this post Link to post Share on other sites
BMW1 44 #6 Posted July 7, 2023 Does anyone know where to get a replacement strainer. All the ones I found on the internet have the correct NPT thread size but the strainer is larger than the thread size. Share this post Link to post Share on other sites
