wallfish 18,813 #26 Posted May 15 2 minutes ago, HyperPete said: once oil & ATF mix, it becomes a homogenous mixture That's what I was think'n too until you spilled it off the top. That hydraulic system should mix that fluid in the reservoir pretty good since it's peeing there whenever the pump is running so having a top layer doesn't compute, unless it separated 1 Share this post Link to post Share on other sites
HyperPete 886 #27 Posted May 15 1 minute ago, wallfish said: That's what I was think'n too until you spilled it off the top. That hydraulic system should mix that fluid in the reservoir pretty good since it's peeing there whenever the pump is running so having a top layer doesn't compute, unless it separated Well, I intend to find out! The only other possibility I can think of would be a badly internally leaking cylinder that prevents it from filling (& mixing) properly.. I'll find out soon. If not tomorrow, next week. Donna & I, her sister & brother-in-law are going to "Boardwalk Rock" in Ocean City, MD this weekend. That should blow off some steam! https://www.boardwalkrockfest.com/ 1 Share this post Link to post Share on other sites
