ebinmaine 81,289 #26 Posted July 4, 2023 7 hours ago, D_Mac said: I just went through the carburetor replacement nightmare. If yours can be rebuilt, rebuild it. If you need a replacement, buy one from Isavetractors. Excellent picture. This clearly shows the wear in the upper shaft bore. IF the lower shaft bore is still fairly tight you/I /someone can add the bushings to the 7/16" diameter hole and save the carb. Share this post Link to post Share on other sites
