Jrblanke 976 #1 Posted July 2, 2023 Hey guys, any idea what transmission. This is? This one came out of the tractor @wallfish built at the 2022 wheel horse show. But I can't remember what it was. I looked through some of the manuals and watched a couple of @stevasaurus videos. at first i thought it was a 1967-68 5060 trans...but it has a dip stick tube. So I'm thinking it's later. James Share this post Link to post Share on other sites
Pullstart 71,012 #2 Posted July 2, 2023 Looks like an 8 speed. 1” or 1-1/8” axles Sue? 2 Share this post Link to post Share on other sites
WHX?? 57,646 #3 Posted July 2, 2023 48 minutes ago, Pullstart said: Looks like an 8 speed. 1” or 1-1/8” axles Sue? You callin him a boy named Sue Kev? ... Brake hub and hubs say later but if ' Fish put it together all bets are off. 1 3 Share this post Link to post Share on other sites
ebinmaine 80,094 #4 Posted July 2, 2023 5 hours ago, Pullstart said: Looks like an 8 speed. Definitely not a 6 speed. See the brake drum location. This is a 5060 6 speed with Limited Slip Differential. Brake drum right beside the axle tube. Share this post Link to post Share on other sites
wallfish 20,386 #5 Posted July 2, 2023 Came out of a Raider. Someone beat on the hub and knocked the axle out. 6 hours ago, WHX?? said: You callin him a boy named Sue Kev? ... Brake hub and hubs say later but if ' Fish put it together all bets are off. We did a complete trans swap and put a tractor together. Not build a trans but you're absolutely right if I did. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #6 Posted July 2, 2023 Just a guess 1 Share this post Link to post Share on other sites
Pullstart 71,012 #7 Posted July 2, 2023 8 hours ago, WHX?? said: You callin him a boy named Sue Kev? ... Brake hub and hubs say later but if ' Fish put it together all bets are off. Another thread the Dino got his name wrong. He said he didn’t mind… Bill or George or anything but Sue. Well… I had to 5 Share this post Link to post Share on other sites
squonk 47,784 #8 Posted July 2, 2023 (edited) 8 spd. All you really need to know is what the axle length and diameter is. Hubs look like the HD ones so I would say 1 1/8" Lowell has bearings and gasket. A-Z has the axles and any gears you might need. Everything is the same internally with all the 8 spds except the number of pinions. Tear it apart. Let's see what it needs. Probably doesn't need any more than a gasket and c clip. Edited July 2, 2023 by squonk 2 Share this post Link to post Share on other sites
Bill D 3,063 #9 Posted July 2, 2023 Since it's painted black, does that mean it came out of a Work Horse tractor? Share this post Link to post Share on other sites
stevasaurus 23,784 #10 Posted July 2, 2023 If it has 1 1/8" axles and is a Limited Slip, it is a 5073. Raider trans with dipstick. Brake drum on cluster gear shaft. If it has 1" axles, it is a 4 pinion #5086...Raider. An 8 pinion 8 speed has 1 1/8" axles. A 4 pinion 8 speed has 1" axles. Brake drum on cluster gear shaft. 2 1 Share this post Link to post Share on other sites
Jrblanke 976 #11 Posted July 2, 2023 1 hour ago, stevasaurus said: If it has 1 1/8" axles and is a Limited Slip, it is a 5073. Raider trans with dipstick. Brake drum on cluster gear shaft. If it has 1" axles, it is a 4 pinion #5086...Raider. An 8 pinion 8 speed has 1 1/8" axles. A 4 pinion 8 speed has 1" axles. Brake drum on cluster gear shaft. It has 1" axles. I'll have to watch a couple more videos of yours to figure out what the cluster gear shaft is, haha. 2 Share this post Link to post Share on other sites
squonk 47,784 #12 Posted July 2, 2023 22 minutes ago, Jrblanke said: It has 1" axles. I'll have to watch a couple more videos of yours to figure out what the cluster gear shaft is, haha. The cluster gear shaft is what the brake drum is on. Pretty simple to fix. Toss it in the Cadachevy. Drive to NY in August for the Steam Pageant. We'll tear it down and see what it needs and reassemble it so you know how it goes together. I'll supply the pie 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,094 #13 Posted July 2, 2023 1 hour ago, squonk said: pie Pie??? 🥧 1 Share this post Link to post Share on other sites
Jrblanke 976 #14 Posted July 2, 2023 (edited) 2 hours ago, squonk said: The cluster gear shaft is what the brake drum is on. Pretty simple to fix. Toss it in the Cadachevy. Drive to NY in August for the Steam Pageant. We'll tear it down and see what it needs and reassemble it so you know how it goes together. I'll supply the pie Hahaha, well, I calculated at 3.80 per gallon at 16mpg for 1220 mile round trip, it would be about 300 bucks. As tempting as some Mennonite rhubarb and shoo fly pie might be... I'll just zip apart the trans and see what I find. I'm just tried of tripping over it in my shed. Worst comes to worst, I'll have some nice hubs and I'll throw the gears on ebay. Here is my daughter trying a bite of the shoo fly pie you brought me! Edited July 2, 2023 by Jrblanke 1 1 2 Share this post Link to post Share on other sites
ebinmaine 80,094 #15 Posted July 2, 2023 10 minutes ago, Jrblanke said: Worst comes to worst, I'll have some nice hubs..... ..... On each side of a nicely redone transmission. I'd bet that's an easily solved issue. 1 Share this post Link to post Share on other sites
Jrblanke 976 #16 Posted July 2, 2023 2 hours ago, ebinmaine said: ..... On each side of a nicely redone transmission. I'd bet that's an easily solved issue. Just watched your video on splitting a case. Good stuff! 1 Share this post Link to post Share on other sites
WHX?? 57,646 #17 Posted July 2, 2023 3 hours ago, Jrblanke said: 3.80 per gallon Wow and I thought 3.59 was stiff.. 3 hours ago, Jrblanke said: I'll throw the gears on ebay. Like hell you will... you will get them to a good member here! 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,094 #18 Posted July 3, 2023 41 minutes ago, Jrblanke said: Just watched your video on splitting a case. Good stuff! I'm VERY happy you found that useful. 1 Share this post Link to post Share on other sites
Jrblanke 976 #19 Posted July 3, 2023 35 minutes ago, WHX?? said: Wow and I thought 3.59 was stiff.. Like hell you will... you will get them to a good member here! I gotta run 89 or 93 through the 6.2L. Regular is about 3.30 around here now. Share this post Link to post Share on other sites
ebinmaine 80,094 #20 Posted July 3, 2023 1 hour ago, Jrblanke said: Just watched your video on splitting a case. Good stuff! Here's a link to that for the folks reading this in the future. Share this post Link to post Share on other sites
