Scott Gilmore 0 #1 Posted July 2, 2023 Replaced starter, worked a couple times, then battery and solenoid no voltage to ignition, just one post on solenoid... Share this post Link to post Share on other sites
Scott Gilmore 0 #2 Posted July 2, 2023 1 hour ago, Scott Gilmore said: Replaced starter, worked a couple times, then battery and solenoid no voltage to ignition, just one post on solenoid... Still no voltage anywhere, just solenoid Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,389 #3 Posted July 2, 2023 Download this file. Each circuit has it's own diagram. Sounds like the 25 amp fuse has blown. 2 1 Share this post Link to post Share on other sites
Scott Gilmore 0 #4 Posted July 2, 2023 No voltage to fuse Share this post Link to post Share on other sites
peter lena 9,187 #5 Posted July 2, 2023 @Scott Gilmore wiring issues are quite common , long setting , tight , chafing , wiring , corrosion , poor grounding , while you are in the electrical phase . improve the electrical rectifier , under the air filter lift off cover area . note the 3 prong oblong electrical hook up front of engine ? add a ground cable from battery ground cable point to corner of engine / frame left rear corner . also loosen up the 2 screws that hold down the rectifier to cooling tin mount spot , dielectric grease , to insure conductivity . start up amp gauge working ? charging ? you just insured engine block grounding to ensure rectifier , response . also wire cable wrap tight spots , take advantage of what works and enhance it . stay after it , pete Share this post Link to post Share on other sites
Scott Gilmore 0 #6 Posted July 2, 2023 No voltage, not low voltage . Dash won't lite up .can't find voltage anywhere but big lead on solenoid. If I jumper voltage to small lead it will turn over. No headlines or tail lites. Pulled wires on rectifier, no voltage. Share this post Link to post Share on other sites
Scott Gilmore 0 #7 Posted July 2, 2023 update got main wires crossed on solenoid when I changed it. Kinda helped putting them on right. Just seemed weird them crossing instead of going in " order" Share this post Link to post Share on other sites
