SaintJay 9 #1 Posted June 27, 2023 Hi guys, I am swapping a K341s into my GT1142 (blew up the B&S 11 hp) and I was hoping you all could help with a few questions I have, so far. Key size or part number for the drive pulley/output shaft keyway? Simple wiring diagram to get it running? I don't need to connect all the safety switches, I just want to turn the key and start it. This is my first engine swap so I'm a little out of my depth. Thanks for any help, Share this post Link to post Share on other sites
John2189 594 #2 Posted June 27, 2023 Safety switches are there for a reason, I would be sure they worked 1 Share this post Link to post Share on other sites
ineedanother 2,621 #3 Posted June 27, 2023 2 hours ago, SaintJay said: I don't need to connect all the safety switches, I just want to turn the key and start it. I get it. Just to run during the swap. Will this work? Not sure which k341 you have... 1 Share this post Link to post Share on other sites
kpinnc 18,756 #4 Posted June 28, 2023 K341 would be coil ignition. The Briggs you're replacing was magneto ignition. Everything electrical from the key switch to the engine has to be different. It's not much, but the two work very differently. 2 Share this post Link to post Share on other sites
SaintJay 9 #5 Posted June 28, 2023 Yes, the B&S had magneto ignition and the K341s has a coil. I am trying to follow the wiring on my C165 as a guide. The problem I am having is that my C165 hasn't been charging the battery. I believe that the rectifier was removed prior to me getting it. I just ordered 2 of them and a new ignition switch for the GT1142. Ineedanother thanks for the diagram. I think that will put me on the right track. How about the key for the output shaft/drive pulley keyway? Anybody know a size or part number? Thanks for the help, Share this post Link to post Share on other sites
squonk 47,421 #6 Posted June 28, 2023 Pretty sure the key is1/4" square stock. You can by a stick at Napa or Tractor Supply and cut it to the length you want. Share this post Link to post Share on other sites
