moe1965 774 #1 Posted June 26, 2023 I'm looking for a ignition switch or a part number for one so I can order one for a C141 I know the ones at the box store are not the right ones they are not just a plug and play. Thanks in advance Share this post Link to post Share on other sites
ri702bill 11,149 #2 Posted June 26, 2023 Soooo much can change over the years - Kohler K series or Magnum?? Switches are not the same... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #3 Posted June 26, 2023 1 Share this post Link to post Share on other sites
moe1965 774 #4 Posted June 27, 2023 Kohler K series. 1979 C 141 Share this post Link to post Share on other sites
Achto 30,864 #5 Posted June 27, 2023 2 hours ago, moe1965 said: Kohler K series. 1979 C 141 Here is the important thing to look for when getting a new ignition switch. If you have an automotive style / battery ignition - the switch has to have an "I" terminal. = Sends positive power to the coil to run. If you have a magneto ignition - the switch has to have a "M" terminal. = Grounds out the coil to kill the engine. As long as you have the right style switch you can always reconfigure the terminals in the switch plug to make the new switch work on your tractor. 1 2 Share this post Link to post Share on other sites
