ANTPER 215 #1 Posted June 20, 2023 Hello Folks I honestly spent lots of time trying to find a correct fuel bowl gasket on my own without bother anyone but If given up. Bought on line and of course its a tad to small. I'm trying get seal on its own if possible. 310-08 with Magnum Kohler. M10S not sure if more info needed. Anthony 1 Share this post Link to post Share on other sites
ri702bill 12,499 #2 Posted June 20, 2023 Anthony - you may be better off buying a sheet or two of gasket material - one heavy paper, the other semi-rigid silicone, and making your own... Trace the inverted bowl on it, offset a line xx inches inside it to seal. Cut the ID first, then the OD.... 3 Share this post Link to post Share on other sites
ANTPER 215 #3 Posted June 20, 2023 1 minute ago, ri702bill said: Anthony - you may be better off buying a sheet or two of gasket material - one heavy paper, the other semi-rigid silicone, and making your own... Trace the inverted bowl on it, offset a line xx inches inside it to seal. Cut the ID first, then the OD.... I honestly was considering that also. Thanks 1 Share this post Link to post Share on other sites
squonk 47,421 #4 Posted June 20, 2023 (edited) That may be a Wabro carb that's a whole nother animal compared to a std. Kohler carb. Do you have the carb number? Edited June 20, 2023 by squonk 2 Share this post Link to post Share on other sites
ANTPER 215 #5 Posted June 20, 2023 6 minutes ago, squonk said: That may be a Wabro carb that's a whole nother animal compared to a std. Kohler carb. Do you have the carb number? I'll try to acquire it now Share this post Link to post Share on other sites
D_Mac 9,337 #6 Posted June 20, 2023 I just ordered a kit from Isavetractors for my 310-8 . Share this post Link to post Share on other sites
squonk 47,421 #7 Posted June 20, 2023 1 hour ago, D_Mac said: I just ordered a kit from Isavetractors for my 310-8 . You might not have the same carb. I have found those crappy Walbro's on all kinds of models. Share this post Link to post Share on other sites
ANTPER 215 #8 Posted June 20, 2023 3 hours ago, squonk said: That may be a Wabro carb that's a whole nother animal compared to a std. Kohler carb. Do you have the carb number? You are correct. Wabro. 47 053 86 is one serirs of numbers. Next WHG 712892 Share this post Link to post Share on other sites
squonk 47,421 #9 Posted June 20, 2023 (edited) Kit is a # 47-853-20 You may have a difficult time finding a kit. I do see some Walbro bowl gaskets on Amazon and some small engine sites Edited June 20, 2023 by squonk 1 Share this post Link to post Share on other sites
ANTPER 215 #10 Posted June 20, 2023 Thanks for feed back everyone. Share this post Link to post Share on other sites
