ebinmaine 80,714 #2 Posted June 17, 2023 Awesomeness! Thanks Joe! 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #3 Posted June 17, 2023 @JoeM very nice! Are those wings off a blower or did you fab them? 1 Share this post Link to post Share on other sites
JoeM 10,268 #4 Posted June 17, 2023 1 hour ago, SylvanLakeWH said: Are those wings off a blower or did you fab them? Home made, tks We don't get enough snow to push. EB ended up with them and was asking how they mount. I am sure they will get a work out up there. 2 1 Share this post Link to post Share on other sites
Pullstart 71,256 #5 Posted June 17, 2023 What about a trip function? Still work, but rock forward over the pile? 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #6 Posted June 17, 2023 10 minutes ago, Pullstart said: What about a trip function? Still work, but rock forward over the pile? Good idea but my plow doesn't trip much. Share this post Link to post Share on other sites
JoeM 10,268 #7 Posted June 17, 2023 I guess they work, I don't trip much. Probably cut those top slots a little longer if need be?? 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #8 Posted June 17, 2023 Just now, JoeM said: I guess they work, I don't trip much. Probably cut those top slots a little longer if need be?? That would do it. Share this post Link to post Share on other sites
Handy Don 17,474 #9 Posted June 17, 2023 (edited) 3 hours ago, JoeM said: for EB Just like those big yellow airport runway snowplows! Very neat. Edited June 17, 2023 by Handy Don 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #10 Posted June 17, 2023 1 minute ago, Handy Don said: Just like those big yellow airport runway snowplows! Very neat. Or large parking lot. With the wide area we have to clear I figured something like this would be a good idea. Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #11 Posted June 17, 2023 2 hours ago, ebinmaine said: Good idea but my plow doesn't trip much. What... no rocks to hit around there? 1 Share this post Link to post Share on other sites
ri702bill 13,068 #12 Posted June 17, 2023 Or, it would make for one Industrial Grade backyard Pooper-Scooper!! 1 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #13 Posted June 17, 2023 5 hours ago, SylvanLakeWH said: What... no rocks to hit around there? Not in the driveway. 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #14 Posted June 21, 2023 On 6/17/2023 at 8:37 AM, JoeM said: EB ended up with them Got em up here yesterday. They look excellent!! 1 Share this post Link to post Share on other sites
JayGee 1 #15 Posted August 12, 2023 Are you still using the MANUAL lift for the snow plow or have you modified it to Hydraulic or Electric lift? Share this post Link to post Share on other sites
ebinmaine 80,714 #16 Posted August 13, 2023 18 hours ago, JayGee said: Are you still using the MANUAL lift for the snow plow or have you modified it to Hydraulic or Electric lift? I have 2 tractors that can be setup for snow/dirt dozers. I used to use a 48" plow with no extra weight or wings. That can be easily lifted with the Manual Lift. Last year I swapped over to a Hydro/Automatic Tractor with a monster plow that has a 1/2" thick - 60" wide skid steer blade on it. The cutting edge ALONE weighs about as much as a whole 42" plow assembly. THAT'S the beast I'm adding the side wings too. You bet it has Hydro Lift!! 2 Share this post Link to post Share on other sites
ebinmaine 80,714 #17 Posted January 24, 2024 Got a set of brackets in the post yesterday. I'll use these to bolt the side plates on to my 48" plow blade. On 6/17/2023 at 7:05 AM, SylvanLakeWH said: @JoeM very nice! Are those wings off a blower or did you fab them? Jim, for a size scale these are about 16" square. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #18 Posted November 28, 2025 Well. Here we are almost 2 years later. I've been using my 60" wide @wallfish -bilt plow for a few seasons. Works great but I wanted to try something a little different this year. Like any plow, the snow windrow escapes the tailing edge. Obvious. But it also escapes the forward edge. This year I'll have the above SUPER SCOOPER!! This should allow me to grab a half width or so of snow and just push it right in to the forest. The brackets in the previous post weren't quite wide enough because of interference to the plow frame bracing. I used a set with double holes per side but bolted only one hole 🕳 per. If the side scoops are flappity then I can add more bolts 🔩 or even consider a couple 45⁰ top braces. The 42" wide moldboard I chose is in really tough shape. Severely worn on the bottom and bent at the top. For those reasons I didn't feel too awful bad about drilling it. If this experiment goes well in principle I can consider using a 48" wide set-up. Here's the pics... now for some snow!! 2 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #19 Posted November 28, 2025 Excellent! I love the L bracket Frankenstein look!!! 3 Share this post Link to post Share on other sites
ebinmaine 80,714 #20 Posted November 28, 2025 34 minutes ago, SylvanLakeWH said: Excellent! I love the L bracket Frankenstein look!!! They'll get painted if the idea works out. I may add braces tomorrow. 1 2 Share this post Link to post Share on other sites
pfrederi 21,151 #21 Posted November 29, 2025 Looks like the big rigs they use to clear shopping mall parking lots... 1 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #22 Posted November 29, 2025 12 minutes ago, pfrederi said: Looks like the big rigs they use to clear shopping mall parking lots... Wheelhorse version! Share this post Link to post Share on other sites
ebinmaine 80,714 #23 Posted December 24, 2025 (edited) Got a chance to really test this machine today. The more I used it - the more I like it. As much as I love SEAT TIME ... this is a VERY efficient way to plow snow. With 6 1/2" down I was able to force a whole scoop and then grab approximately thirds to push forward with minimal side losses. The side scoops are excellent but very weak. The BBT and I - having seen this setup in action - agree that this will need to braced - as previously discussed - AND welded at the edges. I caught a hidden rock at LOW speed. This was after I'd already straightened out the sides TWICE. Folding the brackets was waaay too easy with the weight of the tractor and all the added weight up against the rocks. It will also NEED to have any pivoting motions completely eliminated. This is a straight motion ONLY piece. Plow frame to tractor frame & plow to plow frame must be firm. More improvements soon! Edited December 26, 2025 by ebinmaine 2 Share this post Link to post Share on other sites
JoeM 10,268 #24 Posted December 24, 2025 maybe a tie bar across the top front edge ?? I seen others with vee gusseted too. 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #25 Posted December 24, 2025 5 minutes ago, JoeM said: maybe a tie bar across the top front edge ?? I seen others with vee gusseted too. I'm thinking similar. Maybe a round rod at the front about 1/3 down from the top. I'll likely still do 45⁰ braces at the corners too. 1 Share this post Link to post Share on other sites
