wallfish 20,002 #1 Posted August 9, 2009 I just picked up another money pit today. I guessing a 400 suburban and could use some help to ID what Share this post Link to post Share on other sites
perry 82 #2 Posted August 9, 2009 atleast the hood looks complete. looks a little better than my 400 i hauled in 2 days ago. its allfroze up . Share this post Link to post Share on other sites
fireman 1,022 #3 Posted August 9, 2009 Nice tractor John . I have the manual for that if you need it in PDF format. Share this post Link to post Share on other sites
wallfish 20,002 #4 Posted August 9, 2009 Nice tractor John . I have the manual for that if you need it in PDF format. I could use that Jeff. The drawings at Toro are so faded that you can't see the steering parts. Thanks uremailing@yahoo.com Share this post Link to post Share on other sites
MikesRJ 562 #5 Posted August 9, 2009 Nice find John, looks like you're going to be a busy boy! Share this post Link to post Share on other sites
64s 83 #6 Posted August 9, 2009 John, I'm glad it was one of you guys that beat me to it. Good luck!!! George Share this post Link to post Share on other sites
Coadster32 793 #7 Posted August 10, 2009 I'm pretty sure the steering parts I got are the correct ones. The steering setup on yours looks a little sketchy to me. I also have the seat and spring also. Bid it up man!! Too bad you didn't need them at the last meet-n-greet. You could have gotten them right then. Never know what's around the corner. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,630 #8 Posted August 10, 2009 John, I have a donor 502 frame and some parts (no seat or sheet metal or rear end) but maybe some steering parts... Let me know if the parts from a 502 would work. Share this post Link to post Share on other sites
clintonnut 127 #9 Posted August 10, 2009 I have a seat spring and shifter if you want it. Charlie Share this post Link to post Share on other sites
wallfish 20,002 #10 Posted August 10, 2009 I have a seat spring and shifter if you want it. Charlie I could definately use them Charlie. Let me know how much. Did you get the email I sent earlier today? Share this post Link to post Share on other sites
wallfish 20,002 #11 Posted August 10, 2009 John, I have a donor 502 frame and some parts (no seat or sheet metal or rear end) but maybe some steering parts... Let me know if the parts from a 502 would work. Thanks Steve, I'll see if I win Coadster's stuff on ebay and I think the 502s are front engines which will not work. I haven't looked at the spindles yet but that might be a possibility if they are the same. Share this post Link to post Share on other sites
wallfish 20,002 #12 Posted August 10, 2009 I'm pretty sure the steering parts I got are the correct ones. The steering setup on yours looks a little sketchy to me. I also have the seat and spring also. Bid it up man!! Too bad you didn't need them at the last meet-n-greet. You could have gotten them right then. Never know what's around the corner. If I had the tractor for the meet & greet you wouldn't have those tires I want back :thumbs2: Share this post Link to post Share on other sites
captjake 1 #13 Posted August 10, 2009 Nice tractor! I have two that i'm overhauling. I'll take a few photos of the steering on my 400. Good luck. Share this post Link to post Share on other sites
linen beige 16 #14 Posted August 10, 2009 I am now looking to buy the parts needed to put her back to her original glory, so if anyone can help out with anything please let me know. Items that I know of are: Gas tank, seat spring, shifter, throttle/choke levers, lift cable, belt guard and heat shield. A K-91 or Clinton maybe? The steering should have the gear on the end of the shaft and the geared sector underneath, just like the 401. I'm intrigued by the "hump" in the hood around where the steering shaft goes through. I've not seen that before. I'm also curious as to why the back of the hood is higher than the front. It was probably raised up to clear a larger engine, and the extra holes in the frame indicate it has had one mounted. Did someone alter the wings on the top of the hoodstand that hold the hood sides? Share this post Link to post Share on other sites
tgranthamfd 29 #15 Posted August 10, 2009 Wallfish here is the steering rod, if that is the correct name, that connects to the spindles on each end, and the drag link that connects on the hole towards the middle. and the drag link should look like this. It's not a very good pic. but this is the gear , view from the bottom side of the tractor. Hope this helps, I have a ton of pictures if you need another view, or I completed putting the parts back on this weekend but haven't gotten them uploaded yet. When I get them uploaded, I can show you a pic from the underneith side, if you want. This is a 60 model suburban. Share this post Link to post Share on other sites
wallfish 20,002 #16 Posted August 10, 2009 captjake ---Looks like tgranthamfd sent what I needed for the steering. Thanks tgranthamfd --- Thanks fot the pics linen beige --- I already have a motor and the hump where the steering shaft goes through looks like PO welded in a collar or something. I noticed the hood tilting down in the pics but haven't really looked at the tractor to see why. Share this post Link to post Share on other sites
Coadster32 793 #17 Posted August 10, 2009 If I had the tractor for the meet & greet you wouldn't have those tires I want back How's it feel to want!! I think I might still have the steering link with the ball joints on it kicking around too. When I get a chance, I'll look for you. Share this post Link to post Share on other sites
