Sailman 1,307 #1 Posted June 9, 2023 I scored an all original 701 in pretty good condition. Don't plan to do a restoration, would prefer to keep it as original as possible. Does using penetrol on the tins hurt the value? I had to use some on the tool box and seat support due to so much bare metal after removing the rust, but wondering if its a good idea to do the rest of the tractor with it or not. Want to keep the value as high as possible. Also, better to keep the wheels and tires original? Suggestions? Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #2 Posted June 9, 2023 (edited) I use Penetrol on all old paint. Just did two coats on new to me NOS A-60 electric. Remarkable results. Oh... and Edited June 9, 2023 by SylvanLakeWH 2 Share this post Link to post Share on other sites
rmaynard 17,552 #3 Posted June 9, 2023 I personally just can't let it rust away. Anything that you put on it without removing rust, does nothing to stop or prevent further rust. 2 Share this post Link to post Share on other sites
kpinnc 18,916 #4 Posted June 10, 2023 (edited) 2 hours ago, rmaynard said: I personally just can't let it rust away. Anything that you put on it without removing rust, does nothing to stop or prevent further rust. So true. It's your machine, so by all means what you do is your business. That being said, rust has to be removed to stop it. Light surface rust can be treated with varying degrees of success- but if you can feel it, its too deep to just treat. Edited June 10, 2023 by kpinnc 1 Share this post Link to post Share on other sites
Sailman 1,307 #5 Posted June 11, 2023 Here are the pictures. Does the penetrol treatment to the tins reduce the value of an "original"? I had to use it on the tool box, seat stand and v bracket due to the heavy rust, but tins...not so much rust. I did the oil rub down on the fenders. 2 Share this post Link to post Share on other sites
