hotajax 281 #1 Posted May 26, 2023 When I was a kid putting points in my old Beetle, I used a special grease for the rubbing block on the points. Flash forward 50 years. What is available to do this these days? Synthetic bearing grease? Dilectric grease? Thanks in advance. 1 Share this post Link to post Share on other sites
ri702bill 12,501 #2 Posted May 26, 2023 @squonk, our resident "NAPA-TEER" may be able to steer you towards a supply of Echlin Point Cam Grease - it's like a Twinkie! - lasts forever!! I still have mine from the 1970's!! I so do NOT miss dealing every 5000 mile with auto ignition points closing up.... or losing the little mounting screw!!! 4 Share this post Link to post Share on other sites
stevasaurus 23,746 #3 Posted May 26, 2023 If I remember, that lube was like Vaseline, which may be comparable. The lube I use for my Penn fishing reals resembles that point lube also. Not sure, but I would think either would work. I also have a tube of that kind of lubricant from my Grandfather...probably what they used back then. Thanks for the memories. My guess is Squonk calls it earwax. 2 8 Share this post Link to post Share on other sites
squonk 47,421 #4 Posted May 26, 2023 (edited) 1 hour ago, ri702bill said: @squonk, our resident "NAPA-TEER" may be able to steer you towards a supply of Echlin Point Cam Grease - it's like a Twinkie! - lasts forever!! I still have mine from the 1970's!! I so do NOT miss dealing every 5000 mile with auto ignition points closing up.... or losing the little mounting screw!!! This is what Echlin sells now. I still have my Tube of grease from 1975 when I was known as " Mr. Delco" Edited May 26, 2023 by squonk 5 3 Share this post Link to post Share on other sites
lynnmor 8,914 #5 Posted May 26, 2023 If you Google Lubricam you can find the proper grease, but the price is high. You can try Summit or Jegs to see if you can find better pricing. 2 Share this post Link to post Share on other sites
hotajax 281 #6 Posted May 26, 2023 I got some Red 'n Tacky from Lucas. Supposed to be good to 550 degrees F. If the motor craps out, I'll know why. 3 Share this post Link to post Share on other sites
ri702bill 12,501 #7 Posted May 26, 2023 Do NOT store this in the medicine cabinet next to the Preparation H !!!!! 1 7 Share this post Link to post Share on other sites
pfrederi 20,877 #8 Posted May 26, 2023 What happened to the little capsule of grease that came with new points... 2 1 Share this post Link to post Share on other sites
Wild Bill 633 936 #9 Posted May 26, 2023 You are right, only old guys know what cam lube is. FYI, I store mine next to the bed. That way I always know where it is. And I am told when you get really old it is like pushing a marshmallow thru a button hole. LOL! 5 Share this post Link to post Share on other sites
hotajax 281 #10 Posted May 26, 2023 45 minutes ago, pfrederi said: What happened to the little capsule of grease that came with new points... Fredi: Last two times I put in points, no grease capsule in the box. I went to my neighbor, an old gent who had a tube of this stuff, so that was cool. But he has passed on, and is now spending all his time drinking good bourbon and watching seventh games of the National Hockey League finals. Times have changed. 1 Share this post Link to post Share on other sites
hotajax 281 #11 Posted May 26, 2023 36 minutes ago, Wild Bill 633 said: You are right, only old guys know what cam lube is. FYI, I store mine next to the bed. That way I always know where it is. And I am told when you get really old it is like pushing a marshmallow thru a button hole. LOL! Good thing you keep it by your bed. You never know if the local cheerleaders stop by some night after the basketball game. 3 Share this post Link to post Share on other sites
squonk 47,421 #12 Posted May 26, 2023 Still remember replacing the deteriorated lube wicks on the Delco distributors. 2 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #13 Posted May 27, 2023 2 hours ago, squonk said: Still remember replacing the deteriorated lube wicks on the Delco distributors. Me too. We gettin' old, Mike. I still have my Sun timing light, dwell meter, and vacuum gauge. All in the red plastic carry case. And have occasion to use it from time to time. 2 1 Share this post Link to post Share on other sites
hotajax 281 #14 Posted May 27, 2023 1 hour ago, Wheel-N-It said: Me too. We gettin' old, Mike. I still have my Sun timing light, dwell meter, and vacuum gauge. All in the red plastic carry case. And have occasion to use it from time to time. Sun Timing Light. Now that's an oldie 1 1 Share this post Link to post Share on other sites
squonk 47,421 #15 Posted May 27, 2023 I got a cheapie Sun knock off timing light. Polished chrome. Also have a 45 deg . cable operated 1/4" Dr. dwell adjuster tool. And of course a vacuum gauge. 2 Share this post Link to post Share on other sites
953 nut 67,468 #16 Posted May 27, 2023 Only thing I have with ignition points now is Koehlers and the little push rod that opens the points is splash lubricated. If I did have a need for points lube I would use a small drop of Lucas Assembly lube, that stuff is slick and Greasy Pete Approved. 1 Share this post Link to post Share on other sites
squonk 47,421 #17 Posted May 27, 2023 (edited) Distributor/ carb adjusting tool from Snap On. The slotted screwdriver sockets are long gone. Shown with the 1/8" Delco points adjuster bit along with a 3MM hex bit for those pesky Chrysler 2.2 Holley/Weber mixture screws. This tool also was handy with a 7/16" socket when old Mrs. Hubbs sawed off her side view mirror on her 68 Olds 98! Dwell meter is long gone. It was a good one that would balance cylinders. Last time I was using it I was setting the idle-air mixture on GM Computer Command electronic carbs. Last auto shop I was in we had one of these that actually talked to you! Edited May 27, 2023 by squonk 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #18 Posted May 27, 2023 Did you listen to what it said ? 1 Share this post Link to post Share on other sites
squonk 47,421 #19 Posted May 27, 2023 19 minutes ago, elcamino/wheelhorse said: Did you listen to what it said ? Yes. It said "This Elcamino is too rusty and cranky to fix!" " And it's engine is leaking everywhere! " 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #20 Posted May 27, 2023 That is the reason it went to a new owner. Couldn't get any help from Sir skunky. 1 Share this post Link to post Share on other sites
Sailman 1,307 #21 Posted May 27, 2023 Thanks a lot! Y'all just reminded me how old I am..... 2 Share this post Link to post Share on other sites
953 nut 67,468 #22 Posted May 27, 2023 7 hours ago, Sailman said: Thanks a lot! Y'all just reminded me how old I am..... You aren't the only one. 1 Share this post Link to post Share on other sites
hotajax 281 #23 Posted May 27, 2023 What type of grease is packed in the bearings? Clear greenish / Blue. Is that a high temp grease? Thanks Share this post Link to post Share on other sites
Wheel-N-It 2,978 #24 Posted May 27, 2023 Maybe we should start a new thread of ; Show us your vintage mechanic tools Here is some of my old school test equipment 2 Share this post Link to post Share on other sites
