Countdown To Christmas!
canam1991
Look what i picked up today Am i missing anything?
canam1991
I picked up a 1976 d160 today with front rear pto 3pt hitch, 48" side discharge deck, this 48" snow blower used twice on a asphalt drive way :thumbs2: and a like new snow cab :thumbs::ychain: i'll get more pics tomorrow I know i missing the chute turn shaft but am i missing something that goes under the D160?
Jim_M
You're missing the pivot arms for the snowblower. If I can find my manual I'll scan a good picture for you. If you have your model number Toro probably shows them on the ipl.
canam1991
Jim that would be wonderful because tag is missing :thumbs2: or does someone have a picture of under there tractor? thanks going to get pics of tractor
Jim_M
See the 2 pieces of 3/8" x 1" flat bar that go from the rear of the blower frame to to the holes in the rock shaft? That's all you're missing. You can make them easily enough. I can get you the dimensions, but it will be a few days bfeore I get time to drive out to where the blower is.
canam1991
That would be great would it be easy to make the chute turn shaft thingy?
perry
nice find :thumbs:
you can just drop that cab at my house :thumbs2: .
Jim_M
It could be made easily enough as long as you don't care about having it look 100% original. I'll see if I can find a picture of that side of the tractor.
I don't own this one anymore so if I don't have a picture I won't be able to get one, but I have another blower just like it (not on a tractor).
canam1991
Thanks perry
Jim i don't care what it looks like its a work tractor not a show but could you get me the dimensions of that to while your there? thanks
Jim_M
Yup, will do.
In the mean time here's the parts diagram for a 6-7451 snowblower.
You can see the 2 arms that you're missing, #42. You also need 50, 51 and 52.
If you put the blower on your tractor, set the front of it on a block so that the cutting edge is 4" to 6" off the ground and raise the implement lift all the way up, you can measure from the center of the hole on your plow bracket to the center of the hole in the rock shaft (both sides should measure the same) and you'll know how long to make the arms. They're made of 3/8" x 1" hot rolled bar.
As for the chute crank, you can bend it up out of 3/8" round stock. with the blower on the tractor you should be able to come up with the length, just remember it will move forward and back as you lower or lift the blower, so come up with a length that's a happy medium. part # 50 is the support bracket for the crank, anything that holds the crank about 8" away from the side of the tractor and allows the crank to move forward and back should work just fine for you. #51 slides through the hole in #50.
canam1991
ok thats good enough for the lift brackets got them made but could you measure the crank and take a picture of the bracket? thanks alot
can whlvr
Nice find that machine looks well taken care of.
Jim_M
Yes, but it's going to be a while before I get out that way.
canam1991
ok thats fine
canam1991
Got the cab on it to make sure its all there :thumbs:
and it is :thumbs2: :ychain:
Rogue
Wow! That is a beast. Nice find :thumbs2:
Ro
.5racer
So the blower is a belt drive !!
d180man
HI that is a nices find we are still looking for a cab and blower! :thumbs2: but great find! :thumbs: and to .5racer it is belt down to box then a small pto shaft! :ychain:
baerpath
With minimal effort you take the adaptors off a D250 snow blower for use on the smaller D's. Same blower just different attachments
Duane
canam1991
i,ve never seen a blower on a 250 :thumbs2:
WH953
If you took all the mountings off the back of that blower, I am almost positive it is a twin to my Sears blower. The chute turn shaft, that you are missing, is made up of a solid square shaft, with a crank handle bent on the end of it. That telescopes inside of a hollow square shaft with a open hook, on the end, that connects to the eye hook on the swivel mechanism. I don't have the blower at my house, but if someone else doesn't beat me to it, I'll send you a picture.
canam1991
ok thank you
