Aubreysheppard 1 #1 Posted May 21, 2023 (edited) Edited May 21, 2023 by Aubreysheppard i do not now how to type in the big box but i cant set my govenours right on thhis tractor Share this post Link to post Share on other sites
ebinmaine 77,335 #2 Posted May 21, 2023 Can you please post pics of the ENGINE ID tag? Share this post Link to post Share on other sites
Pullstart 68,882 #3 Posted May 21, 2023 That looks like a Briggs and Stratton? 1 Share this post Link to post Share on other sites
953 nut 64,115 #4 Posted May 21, 2023 how do i set my goveners right to stop it from misfireing What makes you think a governor causes misfiring? Spark timing (points setting) is the likely problem. Share this post Link to post Share on other sites
ebinmaine 77,335 #5 Posted May 21, 2023 26 minutes ago, 953 nut said: Spark timing (points setting) is the likely problem. I'd had that thought too. Or the wire. Or condenser. But that looks like a replacement engine. Might not even have points. Share this post Link to post Share on other sites
stevasaurus 23,617 #6 Posted May 21, 2023 If you are shutting down the engine from full or 3/4 throttle, idle the engine down and let it run for a moment before turning off the key. Could be too much gas in the cylinder. Share this post Link to post Share on other sites
squonk 45,520 #7 Posted May 21, 2023 5 hours ago, Pullstart said: That looks like a Briggs and Stratton? Looks like an IC decal don't it? Share this post Link to post Share on other sites
Pullstart 68,882 #8 Posted May 21, 2023 1 hour ago, squonk said: Looks like an IC decal don't it? I was thinking even the shroud looked like it. Share this post Link to post Share on other sites
