Retired Wrencher 6,982 #1 Posted May 16, 2023 Are these parts on the right side hole for an attachment? I never found what what it is for. P/N 14-85 14-84 14-86 Just asking do not need to use it. Thanks for any info Share this post Link to post Share on other sites
Ed Kennell 47,270 #2 Posted May 16, 2023 (edited) That is the cam lever that engages the PTO bell. The bolt and nut are the pivot that attaches the lever to the engine. Edited May 16, 2023 by Ed Kennell 3 Share this post Link to post Share on other sites
peter lena 10,047 #3 Posted May 16, 2023 @Retired Wrencher if you were to turn that , " trunnion " into a 3/8 x16 , male female heim joint , rethread the rod , with a 3/8 x 24 die nut , it adds a solid smoothness to that wobblily spot , they also stand up , have them for years on my horses , done a batch of things in that area . pete 1 Share this post Link to post Share on other sites
peter lena 10,047 #4 Posted May 16, 2023 @johnnymag3 ,its never one part , its a collection of movement areas , see the greased washers , at starting point next to battery tray ? added those to eliminate slop / play in lever rod., then kept going , firming up every next , movement spot. then went on to hi temp grease every rotational part . set up works , without noise , screaming clutch , or related bearings . greasy , pete 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,982 #5 Posted May 17, 2023 22 hours ago, Ed Kennell said: That is the cam lever that engages the PTO bell. The bolt and nut are the pivot that attaches the lever to the engine. Ed do you have a picture of this? It been awhile since I worked on these. Share this post Link to post Share on other sites
