powderfinger 24 #1 Posted May 13, 2023 Hello, Can anyone help me with the part number for the Wheel horse 857 ignition swiitch part number and whre I can order a replacement? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #2 Posted May 13, 2023 Click on the drawing of the switch May be more than you want to spend https://www.partstree.com/parts/toro-7263/ There are alternatives. 2 Share this post Link to post Share on other sites
Handy Don 15,204 #3 Posted May 13, 2023 48 minutes ago, powderfinger said: Hello, Can anyone help me with the part number for the Wheel horse 857 ignition swiitch part number and whre I can order a replacement? Thanks 2 minutes ago, gwest_ca said: Click on the drawing of the switch This is the switch to use since it is designed to carry the heavy current of the starter motor directly. Switches that look similar, but designed for lower current, are not appropriate. 1 1 Share this post Link to post Share on other sites
squonk 44,867 #4 Posted May 13, 2023 https://wheelhorsepartsandmore.com/product/4988-7263-starter-generator-key-switch/ 2 Share this post Link to post Share on other sites
ri702bill 10,576 #5 Posted May 13, 2023 3 hours ago, Handy Don said: This is the switch to use since it is designed to carry the heavy current of the starter motor directly. Switches that look similar, but designed for lower current, are not appropriate. And THAT is why I added a Solenoid to my 854. Same keyswitch, but it does NOT see the high current load as wired originally. NO issues going on 8 years... Share this post Link to post Share on other sites
powderfinger 24 #6 Posted May 14, 2023 11 hours ago, ri702bill said: And THAT is why I added a Solenoid to my 854. Same keyswitch, but it does NOT see the high current load as wired originally. NO issues going on 8 years... I have a solenoid on this tractor.... Share this post Link to post Share on other sites
powderfinger 24 #7 Posted May 14, 2023 Engine wont turn over. battery is new. I get some stray current from the ignition key when in the start poistion according to the multi-meter?? Share this post Link to post Share on other sites
powderfinger 24 #8 Posted May 14, 2023 15 hours ago, gwest_ca said: Click on the drawing of the switch May be more than you want to spend https://www.partstree.com/parts/toro-7263/ There are alternatives. what are the alternatives? Share this post Link to post Share on other sites
squonk 44,867 #9 Posted May 14, 2023 Doub't it's the switch. Probably something going on with the starter gen. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #10 Posted May 14, 2023 1 hour ago, powderfinger said: what are the alternatives? Add a starter solenoid and lighter duty ignition switch along with smaller gauge wires to the switch. This takes the high amperage load off the switch and shifts it to the solenoid. An existing original switch's life could also be extended by adding a solenoid. 1 Share this post Link to post Share on other sites
powderfinger 24 #11 Posted May 14, 2023 (edited) Guys It has a solenoid. I'll take a pic and post it. thanks for the help. Edited May 14, 2023 by powderfinger Share this post Link to post Share on other sites
Handy Don 15,204 #12 Posted May 14, 2023 (edited) 1 hour ago, powderfinger said: Guys It has a solenoid. I'll take a pic and post it. thanks for the help. So this is a simplified wiring diagram with the solenoid that someone posted on the forum: Assuming it’s the original K-181 engine which uses a coil and points as shown here, be sure there is no continuity between the ignition (I) terminal and the ignition switch body or any other terminal when the key is in the OFF position. Edited May 14, 2023 by Handy Don Share this post Link to post Share on other sites
953 nut 63,035 #13 Posted May 15, 2023 Here is a much better drawing to work from. Uses a 103-990 ignition switch Share this post Link to post Share on other sites
powderfinger 24 #14 Posted June 12, 2023 Thanks guys! I got a switch via amazon for $20. Fired right up 1 Share this post Link to post Share on other sites
