rmaynard 17,549 #1 Posted May 12, 2023 I guess I'll start a new topic here where questions like "how is that done" or how can I do that", can be answered by those who have more knowledge than me. So here is my first question. How do you remove the stud in this idler? I need to replace the bearing and can't for the life of me figure out how this stud is removed. 2 Share this post Link to post Share on other sites
squonk 47,990 #2 Posted May 12, 2023 Press. Use a socket that just fits over the stud so it supports the inner bearing race but the slotted end of the stud will slip thru. Press from the threaded side. 3 Share this post Link to post Share on other sites
ebinmaine 80,461 #4 Posted May 12, 2023 4 hours ago, rmaynard said: stud Interesting setup. These common ? I don't recall seeing one. Share this post Link to post Share on other sites
WHX?? 57,904 #6 Posted May 12, 2023 Clutch idler off a Suburban or maybe a RJ and othersEB ... of course you wouldn't know since you DON'T HAVE A ROUND HOOD! You need one Bob I have some or @prondzy does too. He made a jig for setting rivets back in original instead of nuts n bolts. Turns off the old ones on a lathe. 1 1 1 Share this post Link to post Share on other sites
JAinVA 4,638 #7 Posted May 12, 2023 (edited) If you need to change the bearing,then all the rivets need to come out. That part was never designed to be serviced only replaced. Edited May 12, 2023 by JAinVA 1 Share this post Link to post Share on other sites
rmaynard 17,549 #8 Posted May 13, 2023 8 hours ago, squonk said: Press. Use a socket that just fits over the stud so it supports the inner bearing race but the slotted end of the stud will slip thru. Press from the threaded side. The threaded side is larger than the slotted side. How can it press through? Share this post Link to post Share on other sites
squonk 47,990 #9 Posted May 13, 2023 Is that edge beneath the slot, bigger than the ID of the bearing or is it an illusion in the picture. Share this post Link to post Share on other sites
rmaynard 17,549 #10 Posted May 13, 2023 The slotted end looks like it must be pressed toward the thread side. Threaded shaft is 1/2" diameter which is larger than the inside of the inner race. Share this post Link to post Share on other sites
WHX?? 57,904 #11 Posted May 13, 2023 (edited) Yes remove any burrs and press out from the slotted side. 14 hours ago, JAinVA said: If you need to change the bearing,then all the rivets need to come out. That part was never designed to be serviced only replaced. Correct but where's there a will there's a way. Would guess in 1960 you could walk in a dealer and buy one. Edited May 13, 2023 by WHX?? 2 Share this post Link to post Share on other sites
WHX?? 57,904 #12 Posted May 13, 2023 That particular idler holds a memory for me. 2015 and I had just joined here. A real green horn. Scored my first Suburban 400 and needed that part. Met @Achto here who was building his rat rod at the time. Since it is a custom he had no use for it and sold it to me... 10 bucks I think. When I first met him I thought man this guy is a real dandy putting together a tractor like this. Never in a million did I figure eight years later we hang out. 4 1 2 Share this post Link to post Share on other sites
ebinmaine 80,461 #13 Posted May 13, 2023 39 minutes ago, WHX?? said: Never in a million did I figure eight years later we hang out Some right decent folks on this site ain't they? 1 5 1 Share this post Link to post Share on other sites
peter lena 10,030 #14 Posted May 13, 2023 @WHX?? more than anything , I see the opportunity to hi temp re grease grease that bearing , thats why I like tractor supply pulleys , they regularly have the same size / type of pully with a much bigger bearing and rubber side shields . then its only a matter of getting a size to size bronze bushing to get an exact blot on fit . done that on all of my original whiney belt driven pulleys . you can always paint them red . pete 3 1 Share this post Link to post Share on other sites
EB-80/8inPA 2,115 #15 Posted May 13, 2023 4 hours ago, ebinmaine said: Some right decent folks on this site ain't they? There certainly are - most in fact, but some of these guys are downright inspirational (or humbling depending on how one happens to feel). 2 1 1 Share this post Link to post Share on other sites
WHX?? 57,904 #16 Posted May 14, 2023 9 hours ago, peter lena said: @WHX?? more than anything , I see the opportunity to hi temp re grease grease that bearing Wished I woulda known that back then Greasy Pete... he urged me to lube it with Cap'n... not a wonder how our bromance survived... 1 1 3 Share this post Link to post Share on other sites
Achto 32,476 #17 Posted May 14, 2023 (edited) 29 minutes ago, WHX?? said: he urged me to lube it with Cap'n... not a wonder how our bromance survived Birds of a feather. Edited May 14, 2023 by Achto 2 3 Share this post Link to post Share on other sites
peter lena 10,030 #18 Posted May 14, 2023 @Achto / @WHX?? as you probably know by now , I am in the other zone when it comes to a nagging problem , more often than not , the original functional set up was correct , it was the build cost pull back that made it a problem . after correcting the intent , its the detailing to that , that make things work with solid reliability . thats why I suggest on a recent pick up , take advantage of what works , and enhance that function . just my own 2 cents , think I used to work in Wayne's world . pete 1 3 Share this post Link to post Share on other sites
