Dennis C. 142 #1 Posted April 28, 2023 The carb on my Kohler M14 engine is a Weber. Is the considered a Kohler carb or did someone install a aftermarket carb? I'm trying to set the high and low speed adjustments after a cleaning. Share this post Link to post Share on other sites
pfrederi 21,050 #2 Posted April 28, 2023 (edited) Most magnum single used a Kohler carb. Twins and some spec # singles used Walbro Not aware of any Weber What is spec# of your engine Edited April 28, 2023 by pfrederi Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,454 #3 Posted April 28, 2023 This should be your carb if this is the engine - M14S-601559 https://www.partstree.com/models/73401-314-h-toro-garden-tractor-sn-069000001-069999999-1996/carburetor-6/ 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #4 Posted April 29, 2023 Either a Kohler/Carter #30 or Walbro WHG #60 OR #64...never seen a weber on one Share this post Link to post Share on other sites
oliver2-44 11,694 #5 Posted April 29, 2023 Please post a picture of the Weber carb on it! Share this post Link to post Share on other sites
Dennis C. 142 #6 Posted April 29, 2023 The carb does say WHG on the side and the word WEBER. No #. Once the rain stops, I'll pull the tractor out and take a picture. I agree, it should be a Walbro. Share this post Link to post Share on other sites
Dennis C. 142 #7 Posted April 29, 2023 3 hours ago, oliver2-44 said: Please post a picture of the Weber carb on it! I guess I need new glasses, at 73 these eyes aren't what they used to be. The carb is still on the engine so i took some carb cleaner and thoroughly cleaned the side of the carb with a brass brush. All the letters are able to be read clearly. Yes, a Walbro carb. Still, the carb will nor run at the correct needle settings. Once i have a good warm day, I'll remove the carb and clean. Sorry for the confusion. 1 Share this post Link to post Share on other sites
