WH & IH's 9 #1 Posted April 27, 2023 Hello everyone... I'm new to the square and this would be my first post!! I have two 1972 Raider 14's that have 6 speed 1 1/8 axle 10 pinion LS transmissions. One of them I purchased from the original owner and in pretty good shape for sitting a few years. The second is in rough shape and need lots of TLC in the transmission department. Looking for parts to rebuild and not seeing much out there for pinion replacements, gears, axles (new aftermarket). The plan is to beef it up for serious plowing. Must be venders out there that the pullers are using? Thought I would take a short cut and pick everyone's brain for info. Thanks 3 Share this post Link to post Share on other sites
ebinmaine 80,094 #2 Posted April 27, 2023 8 hours ago, WH & IH's said: Looking for parts to rebuild and not seeing much out there for pinion replacements, gears, axles (new aftermarket). The plan is to beef it up for serious plowing 6 speed, 10 pinion transmissions were used from 1967 to 72 or 73. Parts are available as good used but I haven't seen a new replacement for pinions or axles. Hubs can be sourced from Lincoln at A to Z Tractor in PA. What's the exact issue with your own transmission? To set up for plowing you'll obviously need great traction. Fluid filled tires, plenty of steel weight. You'll be fine. BTW we really like pics of old tractors around here..... 3 Share this post Link to post Share on other sites
Achto 32,265 #3 Posted April 27, 2023 Try A to Z tractors. Best to give him a call with what you need. https://a-z-tractor.business.site/ 1 Share this post Link to post Share on other sites
953 nut 68,190 #4 Posted April 27, 2023 There is a section of Red Square dedicated to PULLERS. You can probably get some good ideas from that section and get to know who is pulling. https://www.wheelhorseforum.com/forum/48-pullers/ Share this post Link to post Share on other sites
Pullstart 71,012 #5 Posted April 27, 2023 In my experience, the Wheel Horse transmission STOCK is pretty dang stout for pulling, working, etc as long as it’s tight and has oil in it. After so many years of abuse, those two factors are the most important. The only other thing that wears them out, is speed shifting and grinding gears. 3 Share this post Link to post Share on other sites
WHX?? 57,646 #6 Posted April 27, 2023 (edited) A stock 5060 or later is great for plowing. I wouldn't worry about parts too much ... they are out there. https://wheelhorsepartsandmore.com/shop-now/ is a good source. Really the only improvements are full length keyways on the axles with 2nd set screw. A-Z has some self locking hubs that are choice. Another upgrade might be to insure you have steel side plates on the diff. Pullers usually lock up the differential but you wouldn't want that for plowing or general use. Pull the transmission apart and see what it needs. Edited April 27, 2023 by WHX?? 2 1 Share this post Link to post Share on other sites
rjg854 13,271 #8 Posted April 27, 2023 I just got a couple of gears from A-Z Tractor for a transmission I'm rebuiilding. 2 Share this post Link to post Share on other sites
oliver2-44 11,662 #9 Posted April 27, 2023 you can also post in the Classified section at the Square for parts. Share this post Link to post Share on other sites
WH & IH's 9 #10 Posted April 27, 2023 That would be correct on the speed shifting and the gears are well rounded on the edges. The shafts have the halfmoon keys all boogered up and not really repairable. Even if I rotated the location. Unless they are welded up and turned back to size but that might raise heck with the hardness. I could reverse engineer the splines and have new ones made. Does anyone think there would be a market for them? (I work at a machine shop). I'll post pics when I get a chance.... 1 Share this post Link to post Share on other sites
ebinmaine 80,094 #11 Posted April 27, 2023 I think there's definitely a market for them but it would be based on supply versus demand like any other thing. Given the fact that good used ones are available anywhere from $30 to $60 each I think I'd seriously consider a new one if it could be done for under $80. Share this post Link to post Share on other sites
WHX?? 57,646 #12 Posted April 27, 2023 3 hours ago, rjg854 said: transmission I'm rebuiilding. And we know you are doing this because the are where??? 1 2 Share this post Link to post Share on other sites
ri702bill 12,699 #13 Posted April 27, 2023 (edited) 2 hours ago, ebinmaine said: I think I'd seriously consider a new one if it could be done for under $80. I have doubts that you could even buy the material for that amount... it only gets cost effective if you are making oodles of them... Had a chance to witness the spline roll forming process back in the mid '80's at Chrysler's Transmission plant in Kokomo. Roll formed, no chip, similar to forging. The shaft area for the spline was turned to the mean diameter of the spline depth. The shaft is suspended on live centers as 2 opposing timed guided wedge shaped tools engage the shaft and roll the spline with about 100 tons of force - half the material goes up, the other half down. (Like rolling a pencil between the palms of your hands with the hands wiping over each other.) One pass and it's done - takes about 8 seconds.... Impressive. Edited April 27, 2023 by ri702bill 1 Share this post Link to post Share on other sites
rjg854 13,271 #14 Posted April 27, 2023 4 hours ago, WHX?? said: And we know you are doing this because the are where??? Once I get all the parts I'll have something to take a picture of. Waiting on bearings, got the gears. 2 Share this post Link to post Share on other sites
WH & IH's 9 #15 Posted April 28, 2023 Splines are cut on these shafts and more than likely made out of 4140 which we use a lot of. Even 9310 if I wanted to get exotic. Chrome Moly would be the ticket if you can find 1 1/8 ground to size. Steel is the cheap part machine time is where the $$$ come in to play if you only do a few sets. I could old school it with a Bridgeport and a index just to proof it out I suppose with some cold roll. (getting the spline correct) 1 Share this post Link to post Share on other sites
ri702bill 12,699 #16 Posted April 28, 2023 On 4/27/2023 at 11:36 AM, ebinmaine said: I think I'd seriously consider a new one if it could be done for under $80. I have doubts that you could even buy the material for that amount. Just had to look - 1-1/8 diameter 4140, 2 feet long is over $90 from McMaster - PLUS shipping............ Share this post Link to post Share on other sites
WHX?? 57,646 #17 Posted April 28, 2023 He works at a machine shop Billl. Bet it would fit in his lunch box... 3 Share this post Link to post Share on other sites
Ed Kennell 46,800 #18 Posted April 28, 2023 45 minutes ago, WHX?? said: Bet it would fit in his lunch box. Like JCs Caddy? 2 2 Share this post Link to post Share on other sites
ebinmaine 80,094 #19 Posted April 28, 2023 1 hour ago, Ed Kennell said: Like JCs Caddy? Best. Song. Ever. Share this post Link to post Share on other sites
WH & IH's 9 #20 Posted April 29, 2023 Ouch boy's..... I know your just razzing me.... but (a) I'm not a thief. (b) home projects are after hours. Materials used.... you buy from the shop. So, we will leave it at that.... I don't know about you guy's but I'm also "cheap" when it comes to buying parts, but I also would pay good money for new parts with quality. Used shafts are ok provided you are not buying someone else's problems like egged out keyways or the shaft seal area wore out. (Still working on the pics) 4 Share this post Link to post Share on other sites
ebinmaine 80,094 #21 Posted April 29, 2023 52 minutes ago, WH & IH's said: I'm also "cheap" when it comes to buying parts, but I also would pay good money for new parts with quality. Exactly my way of thinking. 52 minutes ago, WH & IH's said: Used shafts are ok provided ***** From my experience, A to Z Tractor sells ONLY very good usable parts. That's great for now but eventually the pool will dry up. If I had the availability to use a new shaft for decent price on a heavy worker I'd be pretty interested. Share this post Link to post Share on other sites
rjg854 13,271 #22 Posted April 29, 2023 The axle I just got from Lincoln looked almost brand new. 1 Share this post Link to post Share on other sites
squonk 47,784 #23 Posted April 29, 2023 On 4/27/2023 at 12:52 PM, WHX?? said: And we know you are doing this because the are where??? Here. Can you smell the gear oil? 1 1 1 Share this post Link to post Share on other sites
WHX?? 57,646 #24 Posted April 29, 2023 5 hours ago, squonk said: Here. Can you smell the gear oil? Yes I have a dab behind my ears now... 8 hours ago, WH & IH's said: I know your just razzing me.. Getting one's stones busted happens alot around here... 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,008 #25 Posted April 29, 2023 46 minutes ago, WHX?? said: Yes I have a dab behind my ears now... Getting one's stones busted happens alot around here... You putting cheese curds behind your ears again??? Wait... you sayin' people pick on you??? Who...? When...? oh wait... uhm, forget it... On topic: As mentioned above, AZ and Wheelhorsepartsandmore are both great to work with... 1 Share this post Link to post Share on other sites
