SSE 3 #1 Posted April 3, 2023 Hi, I have a 1990 416-H with the Onan P216. I have an oil leak so I pulled the hydraulic drive pulley off and thought it would be the oil seal #10, started it up and found that it was leaking from gasket #7. So I pulled bearing plate #8 off. I have gasket and seal coming. The question is, should I use hi-temp silicon with the gasket and do I install seal in plate first or after I put plate back on. Thanks 1 Share this post Link to post Share on other sites
lynnmor 9,012 #2 Posted April 3, 2023 I use a light coat of this gasket spray on both sides of the gasket. Install the seal before installing the plate. 1 Share this post Link to post Share on other sites
