Racinbob 13,193 #26 Posted March 5, 2025 I've always had issues with a very short throttle throw from idle to full on the 161's and 181's. This was my fix. 2 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #27 Posted March 6, 2025 20 hours ago, peter lena said: @WHX?? take advantage of any tiny holes in related areas , like cable pull point to , movement cam shaped spot , all my cables have a light extension spring pull , on return , experiment with function / reaction . combo of lube and spring pull is a no brainer . think about it , every time you pull the cable , the spring is enhancing , its function , lube insures it . do your own testing on a problem spot , thats how I started , cables make no dragging noise , verify every change , have to warn you , once you correct a chronic issue , you might try similar detailing , on another spot , my pto lever engage ments are ridiculously , smooth silent / easy , none of related clutch facings are burned out , pete Pete I spray white lithium grease in housing and on cable for smooth action. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #28 Posted March 6, 2025 19 hours ago, Racinbob said: I've always had issues with a very short throttle throw from idle to full on the 161's and 181's. This was my fix. Very interesting set up. Share this post Link to post Share on other sites
peter lena 10,070 #29 Posted March 6, 2025 @Retired Wrencher always look over a chronic issue on its INTENDED FUNCTION , usually very close in its setting , on my cable set ups , regularly add a LIGHT PULL TO CLOSE EXTENSION SPRING ? think about it , every time you engage the dash area , pull , move point , there is spring assist in its movement , to close . my experimental problem / functional control , was a step by step gain , initially , internal super lube oil . eliminated drag , spring pull to close , made it simple , smooth , easy . found a small piece of perforated , metal gave me a go to spring pull point . have the same set up on my 3 horses . the repetition of a problem , shows me the way . you can always paint an improvement RED , so it disappears , pete 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #30 Posted March 7, 2025 I have used them in the past Pete! Thanks. 1 Share this post Link to post Share on other sites
peter lena 10,070 #31 Posted March 7, 2025 @Retired Wrencher , found so many elimination fixes / changes that were , basically firming up and lubricating movement , its stupid easy , one of my favorites is the PTO lever engagement starting point / and related hand off areas . initial look see , to change , barely showes it , love a CHRONIC ISSUE , done more with washers , routing, lubrication and usually a spring added to enhance initial movement engagement , stop buzzing vibration , outer pto cone , clip lever connection buzzing / noisy set up , small extension spring , makes it all good , all of our units are different , yet basically the same idea . my mule drive is so smooth / easy in its function , and been that way for years , and the detailing that changed it , was washer / lubrication based , not going to get into a have to win deal , always look for , RELATED , OPPORTUNITES , thats how I see it , WHAT IF I TRIED THAT ? stay happy , pete 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #32 Posted March 8, 2025 21 hours ago, peter lena said: @Retired Wrencher , found so many elimination fixes / changes that were , basically firming up and lubricating movement , its stupid easy , one of my favorites is the PTO lever engagement starting point / and related hand off areas . initial look see , to change , barely showes it , love a CHRONIC ISSUE , done more with washers , routing, lubrication and usually a spring added to enhance initial movement engagement , stop buzzing vibration , outer pto cone , clip lever connection buzzing / noisy set up , small extension spring , makes it all good , all of our units are different , yet basically the same idea . my mule drive is so smooth / easy in its function , and been that way for years , and the detailing that changed it , was washer / lubrication based , not going to get into a have to win deal , always look for , RELATED , OPPORTUNITES , thats how I see it , WHAT IF I TRIED THAT ? stay happy , pete You as well Pete. Share this post Link to post Share on other sites
