Chrishar 985 #51 Posted July 5, 2023 (edited) Thanking about just cleaning the block and reseating the motor and doing the valves what do y'all think it was not smoking thank I should put rings in too Edited July 5, 2023 by Chrishar 2 Share this post Link to post Share on other sites
Chrishar 985 #52 Posted July 6, 2023 Clean the motor and started putting it back together and painted the gas tank today 1 3 Share this post Link to post Share on other sites
oliver2-44 11,472 #53 Posted July 6, 2023 On 7/5/2023 at 12:32 AM, Chrishar said: Thanking about just cleaning the block and reseating the motor and doing the valves what do y'all think it was not smoking thank I should put rings in too If it wasn’t smoking and you haven’t pulled the piston, I would just do the valves. 1 Share this post Link to post Share on other sites
Chrishar 985 #54 Posted July 6, 2023 That's what I thinking about doing someone has been in it at some point so far it looks really good in side 2 Share this post Link to post Share on other sites
Chrishar 985 #55 Posted July 7, 2023 (edited) Got the motor together and clean the engine prices ready to paint them tomorrow Edited July 7, 2023 by Chrishar 3 2 Share this post Link to post Share on other sites
Chrishar 985 #56 Posted July 7, 2023 Motor and pieces painted 6 Share this post Link to post Share on other sites
Chrishar 985 #57 Posted July 9, 2023 Got the motor bolted down and put gear oil in the transmission today the old 753 slowly coming back to life 7 1 Share this post Link to post Share on other sites
Pullstart 69,936 #58 Posted July 9, 2023 Looking great! After my 502 resto-mod, the proverbial rolling frame picture means so much more to me! Awesome job! Share this post Link to post Share on other sites
Chrishar 985 #59 Posted July 9, 2023 (edited) Thanks y'all a lot of sweat is in this old 753 Edited July 9, 2023 by Chrishar 2 1 Share this post Link to post Share on other sites
Chrishar 985 #60 Posted July 10, 2023 Put the flywheel and the drive pulley on the motor and clean all the bolts up that go on the motor too going to have to make a new upper steering shaft the old one is way to bad to fix going to be fun trying to drill them holes out 4 Share this post Link to post Share on other sites
Chrishar 985 #61 Posted July 11, 2023 Fix the upper steering shaft and the lift rod and spring assembly and sanded some parts too 5 Share this post Link to post Share on other sites
WHX?? 56,558 #62 Posted July 11, 2023 Looking good Chris. What was your thoughts on a blacked out motor? I did it once on a 1067 resto and it worked and Cindy's 702 just cause I didn't think a red motor would pair well with candy apple. Hindsight being 20/20 I should have stripped the motor and had Dan shoot it in CA. BTW Dan had yer old ride at a show past weekend and claims two pulls to start. SOB never offered me seat time but tooled around on it abit ... 1 Share this post Link to post Share on other sites
Chrishar 985 #63 Posted July 12, 2023 Thats the color i paint all my motors two me it's just to much red need some other color black just goes with the red too me 2 Share this post Link to post Share on other sites
WHX?? 56,558 #64 Posted July 12, 2023 Yep ... Dan has got this thing that SGs need to be black... 2 Share this post Link to post Share on other sites
Chrishar 985 #65 Posted July 13, 2023 (edited) Got some more pieces on tonight the old 753 is getting closer to coming back to life Edited July 13, 2023 by Chrishar 2 5 Share this post Link to post Share on other sites
Chrishar 985 #66 Posted July 14, 2023 Back to the drawing board have to pull the motor back off and take it apart the tabe on the governor cross shaft broke off that's great 😂😂 1 2 Share this post Link to post Share on other sites
Chrishar 985 #67 Posted July 15, 2023 Took the motor all apart and replace the cross shaft what a day but got the motor back on the old 753 yay 2 Share this post Link to post Share on other sites
Chrishar 985 #68 Posted July 15, 2023 Got this far today after putting the motor back on again this old 753 horse 4 1 Share this post Link to post Share on other sites
Chrishar 985 #69 Posted July 17, 2023 (edited) Did little today just some painting on some pices hoping Tuesday to rebuilt the generator then get it on and worked on the wiring next that's the planned this week Edited July 17, 2023 by Chrishar 3 4 Share this post Link to post Share on other sites
Chrishar 985 #70 Posted July 19, 2023 Well ran into a problem the generator was worse than what I thought had to order a new charging coil will have it Friday hoping to have it done that day 2 Share this post Link to post Share on other sites
Chrishar 985 #71 Posted July 19, 2023 September is getting close and still away to go on old 753 2 Share this post Link to post Share on other sites
Chrishar 985 #72 Posted July 21, 2023 Did a little tonight got the ing. coil, the points and adjusted them and the exhaust bracket on 3 1 Share this post Link to post Share on other sites
oliver2-44 11,472 #73 Posted July 21, 2023 Looking good Share this post Link to post Share on other sites
Chrishar 985 #74 Posted July 21, 2023 Thanks a lot of sweet and time Share this post Link to post Share on other sites
rjg854 13,024 #75 Posted July 21, 2023 You'll certainly appreciate it in the end, all the work you put into it. Share this post Link to post Share on other sites
