Chrishar 1,054 #26 Posted May 25, 2023 Had no time to work on it but did a little bit last night work on the gas tank and clean up some parts hope to start working on it soon that's the planned 2 Share this post Link to post Share on other sites
Chrishar 1,054 #27 Posted May 26, 2023 Having time this weekend yay to work on the old 753 started too finish fixing the gas tank on the bolt hole got the steering system a lot better next is to work on the front axle and the pin then rebuilt the transmission 5 2 Share this post Link to post Share on other sites
Chrishar 1,054 #28 Posted May 27, 2023 Did some stuff today too the old 753 need some parts put a wanted add up little at a time it's all apart yay 5 1 Share this post Link to post Share on other sites
Chrishar 1,054 #29 Posted May 30, 2023 Got all the old bearing out and clean the transmission cases and look at all the gears and clean them and some other parts too and the rims on Monday planned on working on the frame Wednesday night got to weld the plate were the transmission bolts too it has some cracks in it 5 Share this post Link to post Share on other sites
Chrishar 1,054 #30 Posted June 3, 2023 Got the rims painted and new tires put on next on the list to do this weekend is to put the transmission back together with new bearings and seals and work on the frame 4 4 Share this post Link to post Share on other sites
Chrishar 1,054 #31 Posted June 6, 2023 Got the transmission and some parts sanded and look at the frame planned on welding on it tomorrow night then started putting the transmission back together 3 1 Share this post Link to post Share on other sites
Chrishar 1,054 #32 Posted June 7, 2023 (edited) Weld the crack on the frame were the transmission bolts too and did a little sanding too Edited June 7, 2023 by Chrishar 5 Share this post Link to post Share on other sites
Chrishar 1,054 #34 Posted June 7, 2023 3 mouths to have it done long way to go still 2 Share this post Link to post Share on other sites
Chrishar 1,054 #35 Posted June 9, 2023 Got the transmission back together today planned on painting the transmission and the frame and some pices tomorrow 6 Share this post Link to post Share on other sites
oliver2-44 11,758 #36 Posted June 9, 2023 Good progress! Looking forward to seeing it at the Temple show 1 Share this post Link to post Share on other sites
Chrishar 1,054 #37 Posted June 10, 2023 Got some pices painted today little at a time 6 1 Share this post Link to post Share on other sites
Chrishar 1,054 #38 Posted June 12, 2023 Put the seals in the transmission got 11 pieces sand hoping to do some more pieces this week 3 1 Share this post Link to post Share on other sites
Chrishar 1,054 #39 Posted June 13, 2023 (edited) Got more pieces painted little closer to having it a rolling chaise again yay Edited June 13, 2023 by Chrishar 2 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,580 #40 Posted June 13, 2023 Looking good! Share this post Link to post Share on other sites
Chrishar 1,054 #41 Posted June 14, 2023 Some of it together today the old 753 slowly coming back to life 7 1 Share this post Link to post Share on other sites
Chrishar 1,054 #42 Posted June 18, 2023 Not going to have much time to work on the old 753 the next two weeks getting ready for our tractor pull and show next weekend then clean up time hope y'all have a good wheel horse show I will be getting back on the old 753 in July have 3 mouths to be done with it 4 Share this post Link to post Share on other sites
Chrishar 1,054 #43 Posted June 20, 2023 Had little time today got some pices painted 3 4 Share this post Link to post Share on other sites
AlexR 3,118 #44 Posted June 21, 2023 Looking great!! Always nice to see the transformation when you are painting. Share this post Link to post Share on other sites
kpinnc 18,970 #45 Posted June 21, 2023 23 hours ago, Chrishar said: Had little time today got some pices painted As impressed as I am with the resto, I have to also say I love the portable hanging racks. That is awesome! 3 Share this post Link to post Share on other sites
Chrishar 1,054 #46 Posted June 28, 2023 The old 753 findly has all four wheels on the ground and some of the steering done too little closer 3 2 1 Share this post Link to post Share on other sites
Chrishar 1,054 #47 Posted June 30, 2023 Did a little put the gear shifter and boot and tie rods and the grease fittings on and gule a new brake lining on the brake piece put some gas in the tank to make sure it does no leak gas let it sit for three days that's what I did tonight to the old 753 5 1 Share this post Link to post Share on other sites
Chrishar 1,054 #48 Posted July 2, 2023 (edited) Got some of the motor apart Edited July 2, 2023 by Chrishar 2 Share this post Link to post Share on other sites
Chrishar 1,054 #49 Posted July 3, 2023 Put more pieces on today little bit closer on the old 753 2 4 Share this post Link to post Share on other sites
Chrishar 1,054 #50 Posted July 5, 2023 Did a little more today installed the ing. switch, push button, solenoid and took some more for the motor apart and clean the old gasket off 4 Share this post Link to post Share on other sites
