Jrodgers04 43 #1 Posted March 24, 2023 (edited) Hey All, Excited to have recently picked up a 520LXI to join my family of C-series. Heading to Maine with it next week, I'll send some pics when it's on site. Appears to be in overall great shape. 625 hours. Runs and drives awesome. The Scenario: When the tractor is off and you turn the steering wheel, the steering wheel just turns...it doesn't actually turn the front wheels. It's not freewheeling, it feels slightly "notchy", like there is some resistance and it feels like you're turning some sort of gear and the splines are contacting something but overcoming the resistance. When the tractor is running, the steering appears to work fine. The steering wheel turns the front wheels without issue. The Question: Is this normal for the power steering setup on these machines? If not, has anyone had experience remediating? It feels weird not to be able to turn the front wheels when the machine is off... Thanks!! Jon Edited March 25, 2023 by Jrodgers04 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,849 #2 Posted March 25, 2023 I don't know if these will help or not 1 Share this post Link to post Share on other sites
Jrodgers04 43 #3 Posted March 25, 2023 51 minutes ago, gwest_ca said: I don't know if these will help or not Wow, great trove of info. I don't see an immediate answer but will definitely keep these handy. Thanks for sharing! Share this post Link to post Share on other sites
Pullstart 68,532 #4 Posted March 25, 2023 Welcome to the Xi club! Mine does not have power steering, so I can’t help there. @PeacemakerJack does Kelli’s have power steering? It would be a great idea upon arrival to inspect the front axle pivot pin. It’s amazing how bad mine was worn and still felt tight on the ground. You’ll have to jack the frame of the tractor up to inspect the pivot pin. https://www.wheelhorseforum.com/topic/92609-xi-series-front-axle-pivot-repair/ 1 Share this post Link to post Share on other sites
Lee1977 7,458 #5 Posted March 25, 2023 There isn't a mechanical connection on that power steering only hydraulic. Must be something with the steering valve for the steering wheel to be free. 1 Share this post Link to post Share on other sites
Jrodgers04 43 #6 Posted March 25, 2023 7 hours ago, Lee1977 said: There isn't a mechanical connection on that power steering only hydraulic. Must be something with the steering valve for the steering wheel to be free. Thank you, that's helpful to confirm the steering wheel shouldn't be free. I'll start troubleshooting the valve and related components. Share this post Link to post Share on other sites
Jrodgers04 43 #7 Posted March 25, 2023 8 hours ago, Pullstart said: Welcome to the Xi club! Mine does not have power steering, so I can’t help there. @PeacemakerJack does Kelli’s have power steering? It would be a great idea upon arrival to inspect the front axle pivot pin. It’s amazing how bad mine was worn and still felt tight on the ground. You’ll have to jack the frame of the tractor up to inspect the pivot pin. https://www.wheelhorseforum.com/topic/92609-xi-series-front-axle-pivot-repair/ Thank you. That looks like fun...I'll take a look. 1 Share this post Link to post Share on other sites
Lee1977 7,458 #8 Posted March 25, 2023 I would check the steering wheel first as it's splined to the shaft. It may have enough contact to still turn the valve. I know the steering wheels used on the 520-H were bad as I had to fix mine. They used pot metal in the wheel and it has no strength. 1 Share this post Link to post Share on other sites
ri702bill 10,594 #9 Posted March 25, 2023 1 hour ago, Lee1977 said: I would check the steering wheel first as it's splined to the shaft. It may have enough contact to still turn the valve. I know the steering wheels used on the 520-H were bad as I had to fix mine. They used pot metal in the wheel and it has no strength. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,849 #10 Posted March 25, 2023 There were 4 different model numbers for the 520Lxi and the serial number identifies the model year. Here is what we have for the model on two pages in no particular order https://www.wheelhorseforum.com/search/?&q=520Lxi&type=downloads_file&search_and_or=or&sortby=relevancy 1 2 Share this post Link to post Share on other sites
Jrodgers04 43 #11 Posted March 26, 2023 8 hours ago, gwest_ca said: There were 4 different model numbers for the 520Lxi and the serial number identifies the model year. Here is what we have for the model on two pages in no particular order https://www.wheelhorseforum.com/search/?&q=520Lxi&type=downloads_file&search_and_or=or&sortby=relevancy Thank you. Apparently mine is a 1998…SN 8900933. Lots of helpful info! Share this post Link to post Share on other sites
Jrodgers04 43 #12 Posted March 26, 2023 11 hours ago, Lee1977 said: I would check the steering wheel first as it's splined to the shaft. It may have enough contact to still turn the valve. I know the steering wheels used on the 520-H were bad as I had to fix mine. They used pot metal in the wheel and it has no strength. Thank you, checked that today. Got the nut and lock washer off but couldn’t get the wheel off the steering shaft, it’s seized. Didn’t want to go crazy and make things worse, but at least was able to see that the shaft was turning with the wheel. Share this post Link to post Share on other sites
Jrodgers04 43 #13 Posted March 26, 2023 One thing I tried today was to see if the steering was compromised in any way when running. It had seemed fine when I test drove it, but today I wedged down concrete block between one of the front tires and a solid object. Then with the machine running, I turned the front tire into the block. The pressure was enough to slide the front of the machine over with no issue, no apparent strain on anything. My theory was if the steering valve was severely compromised, perhaps I’d see the same slippage with the machine running if it was under heavy resistance. 🤷♂️ Guess I’ll just start working it this spring and see how she does. 1 Share this post Link to post Share on other sites
Shynon 7,505 #14 Posted March 26, 2023 Steering valve is run off hydraulics, a cylinder moves the steering sector. So when not running no steering Share this post Link to post Share on other sites
Jrodgers04 43 #15 Posted March 26, 2023 14 hours ago, Shynon said: Steering valve is run off hydraulics, a cylinder moves the steering sector. So when not running no steering Thank you, makes sense. Share this post Link to post Share on other sites
