Gregor 4,847 #1 Posted March 14, 2023 (edited) A friend has a 16HP Kohler on a tractor. I think it's yellow. In one day it went to running perfectly, to smoking like a forest fire. It does still run. There is so much pressure in the crankcase, it blew out the dipstick. I told him the only thing I could think of to cause that, would be a broken ring. Am I overlooking something? Any other ideas? Thanks Greg Edited March 14, 2023 by Gregor 1 Share this post Link to post Share on other sites
Ed Kennell 44,891 #2 Posted March 14, 2023 9 minutes ago, Gregor said: Any other ideas? Clogged breather filter. 3 1 1 Share this post Link to post Share on other sites
953 nut 64,125 #3 Posted March 14, 2023 Leaky diaphragm in the fuel pump allowing gas to dilute the oil and overfill the crank case? I bought a parts tractor that was sold because it smoked heavily, oil was very thin and way above full. Changed the oil and bypassed the fuel pump using an electric pump and the smoke went away. 4 1 1 Share this post Link to post Share on other sites
Pullstart 68,883 #4 Posted March 14, 2023 Wrong state? It would be much happier in MI 2 2 Share this post Link to post Share on other sites
peter lena 9,765 #5 Posted March 14, 2023 @Gregor agree with others above , think its a combination of clogged breather and fuel pump diaphram . typically neglected engines , and erratic or non existent service adds up to smoking engines , not saying it could not be a broken ring , if it were me , would try a separate gallon of heavily treated fresh fuel , and just get some easy run time on it , testing / trying / improving run function as it goes . did that on a few engines , also did the multi weight oil / added zink , as a cleaning flushing agent as the chemical fuel cleaning takes effect . would bet that engine has seen terrific neglect / abuse . engines I did that to , came back , with hours of runtime and oil flushing / color / debris removal , carb bowl was also loaded with crud , regularly check out my stuff for feedback , they talk to you with issues , just my experience , pete 1 Share this post Link to post Share on other sites
lynnmor 8,628 #6 Posted March 14, 2023 If it is a OHV Kohler, a blown head gasket can cause such a problem. 2 Share this post Link to post Share on other sites
peter lena 9,765 #7 Posted March 14, 2023 @lynnmor the overall condition of this , that gasket would not surprise me . probably a collection of issues / failures . pete 1 Share this post Link to post Share on other sites
