stevasaurus 23,515 #1 Posted July 25, 2009 gents...I have a HT55C on a 502 that I am trying to get started. Got compresion, changed oil and it might start if the recoil would enguage more than the last 6 inches of the pull. I pulled off the recoil piece and found a piece that is supposed to joilt out and enguage the flywheel when you pull the rope I took the 2 screw out that hold a cover over this piece...has a small spring attached to the cover and a piece of metal, about an inch long that looks (from the top) like a coma. The coma part looks like it could be worn where it fits in the cover...I cleaned and WD-40'd the parts and put it back together. The mechanisem works until I put the recoil back on the flywheel. If I jiggle the rope a little, the cog catches and I can give the engine a good pull. Question...is the trouble the cog piece and if so ...can I get one somewhere. The teeth on the flywheel look OK, and the recoil spring on the pull rope is good. thanks Share this post Link to post Share on other sites
