Wayne0 1,525 #1 Posted March 5, 2023 Probably a stupid question, but on both my '84 Workhorse and my 520H I have to hold the lever to maintain speed. Also, in reverse, the 520 is half as fast as the Workhorse. Ideas? TIA. 2 Share this post Link to post Share on other sites
stevasaurus 23,620 #2 Posted March 5, 2023 A common problem. There are some fixes to what you have. The Hydro guys need to check in here.. 1 Share this post Link to post Share on other sites
rmaynard 16,887 #3 Posted March 5, 2023 Can't tell you anything about the Workhorse, but proper adjustments to the 520's linkage and cam plate can get more movement in the reverse direction, thereby increasing speed. Tightening the tension nut on the cam plate of the 520 can help keep it from moving on it's own. You might also have a lot of slop in the linkage that would not allow it to reverse all the way. Also, a foot control fixes all. 2 Share this post Link to post Share on other sites
Handy Don 15,999 #4 Posted March 6, 2023 1 hour ago, Wayne0 said: Probably a stupid question Definitely not. There are a number of reasons for lack of positive, full-range motion control. Most are readily resolved. You should begin with the steps on Page 13 of the Eaton 11 service manual here. Simple wear in the mechanism is the most common. For example, the cam plate can become wallowed out so that it no longer moves the hydro motor control arm fully. I'll add one other note. When looking at the linkage under the center plate, be sure there is nothing interfering with the full range of its travel. 2 Share this post Link to post Share on other sites
Wayne0 1,525 #5 Posted March 6, 2023 Thanks guys. When the weather warms up, I'll get into it. 3 Share this post Link to post Share on other sites
953 nut 64,283 #6 Posted March 6, 2023 Take a look under the cover over your motion control mechanism. Mine was full of nut shells and rodent nesting and wouldn't go to full forward or back. 3 1 Share this post Link to post Share on other sites
