Bill G 24 #1 Posted February 21, 2023 Need some help locating a new carb or possible a rebuild kit for my kohler magnum 12 motor . Any help would be great . Also any info on valve adjustment for same motor . Thank you , Bill 1 Share this post Link to post Share on other sites
WHX?? 55,996 #2 Posted February 21, 2023 Carb kits are available all over the jungle or fleabay. Just search on Kohler carb. Stay away from the cheap knockoffs as the inlet parts do not often fit. They are OK if you just need the bowl gaskets but for a full rebuild get one that says Kohler on it. See if we can get you a magnum manual the valve adjustments will be there along with other good stuff. 2 1 Share this post Link to post Share on other sites
Ed Kennell 45,662 #3 Posted February 21, 2023 If you do buy a new Asian carb, be aware the choke levers are often backwards. 3 1 Share this post Link to post Share on other sites
WHX?? 55,996 #4 Posted February 21, 2023 I would still endeavor to save the original. Big thing is the throttle bushing shot but guys here @ebinmaine are pros at replacing them too. Some have good luck with the complete knock off some not. 2 Share this post Link to post Share on other sites
WHX?? 55,996 #6 Posted February 21, 2023 Thank you Paul.. I am challenged on posting those on a device that is smarter than I! 3 Share this post Link to post Share on other sites
Brockport Bill 2,275 #7 Posted February 21, 2023 here is the Kohler link i use for Kohler parts ------ https://kohlerenginesparts.com/?lid=6076dg164f141b5030d5ab15&loc=12601 here is the Kohler Engine home page direct link to the Magnum i believe you are seeking ...https://origin.kohlerenginesparts.com/oemparts/c/kohler_engines_magnum_m_mv8_20/parts 1 Share this post Link to post Share on other sites
ebinmaine 78,185 #8 Posted February 21, 2023 8 hours ago, Bill G said: carb or possible a rebuild kit What's the exact reason for needing a carb rebuild? 7 hours ago, WHX?? said: I would still endeavor to save the original. Big thing is the throttle bushing shot but guys here @ebinmaine are pros at replacing them too. Some have good luck with the complete knock off some not. I'd be happy to help if I can. 2 Share this post Link to post Share on other sites
WHX?? 55,996 #9 Posted February 22, 2023 1 hour ago, ebinmaine said: I'd be happy to help if I can Some day yer gonna get a butt pile of them to have your way with... 1 Share this post Link to post Share on other sites
ebinmaine 78,185 #10 Posted February 22, 2023 6 minutes ago, WHX?? said: Some day yer gonna get a butt pile of them to have your way with... I'll trade you some carb rebuilding skills for some hub groove cutting skills. 1 1 Share this post Link to post Share on other sites
ranger 1,851 #11 Posted February 22, 2023 16 hours ago, ebinmaine said: I'll trade you some carb rebuilding skills for some hub groove cutting skills. Who needs grooves in the hubs if you had hubs like these. Saw this at the local agricultural dealer’s open day, last week, free entry,🍺 and hog roast as well!🐷👍. The tractor’s even the right colour! 1 Share this post Link to post Share on other sites
ebinmaine 78,185 #12 Posted February 22, 2023 8 minutes ago, ranger said: if you had hubs like these Niiiiice. We can get something similar from Lincoln at A to Z Tractor. Share this post Link to post Share on other sites
ranger 1,851 #13 Posted February 22, 2023 The threaded holes under the black plastic plugs accept bolts, which when tightened, break the taper allowing the hub to be adjusted in or out. 1 Share this post Link to post Share on other sites
