bitten 134 #1 Posted February 19, 2023 Hello Everyone. I am trying to remove the drive pulley off of the engine to install on replacement engine. I have removed the bolt and spacer that appears to hold the pulley in place. I cant see anything else holding the pulley in place, am I missing something? I also dont see anyway to hook a puller up to it to pull it off. Any help would be highly appreciated. 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #2 Posted February 19, 2023 Remove the set screws in the side of the pulley, sometimes 2 screws, one on top of the other. Sometimes 2 set screw holes, i.e. 12 o' clock & 3 o'clock.... Spray down with penetrating oil in the screw holes & crank. Hook up a puller & remove. 1 4 Share this post Link to post Share on other sites
bitten 134 #3 Posted February 19, 2023 Blasterdad thank you for your response but the C195 has a much different pully. I can not find any set screws and there is no place to hook up a puller. I will get a photo. 2 Share this post Link to post Share on other sites
WHX?? 54,624 #4 Posted February 20, 2023 (edited) 1 hour ago, Blasterdad said: Remove the set screws in the side of the pulley, sometimes 2 screws, one on top of the other. Sometimes 2 set screw holes, i.e. 12 o' clock & 3 o'clock.... Spray down with penetrating oil in the screw holes & crank. Hook up a puller & remove. Exactly what I had to do Blaster. Same puller & setup. Allen set screws stripped out just looking at them tho so had to drill them out. Take some emery cloth & lube to the crank stub so it doesn't fight you all the way. Yes pics Bitten ... you should have dang near the same thing but the PTO bell and inner bearing race all has to all come off. Pics would help us help you. Edited February 20, 2023 by WHX?? Share this post Link to post Share on other sites
Blasterdad 3,163 #5 Posted February 20, 2023 51 minutes ago, WHX?? said: Take some emery cloth & lube to the crank stub so it doesn't fight you all the way. I just took that pic to show @bitten the set up. The bolts were barely in the pulley finger tight, I didn't actually pull it, just an "instructional" photo. Lol 1 Share this post Link to post Share on other sites
WHX?? 54,624 #6 Posted February 20, 2023 13 minutes ago, Blasterdad said: just an "instructional" photo. Lol No crime in that... 1 Share this post Link to post Share on other sites
