ri702bill 13,084 #1 Posted February 7, 2023 (edited) Working on getting this 1970 32" gear drive deck going again, I found I needed to replace the aftermarket plastic lawnmower wheels on it. I searched the "Parts Department" and found that one of the later 3 blade C series decks I got from @Docwheelhorse had useable wheels with zerk fittings. Both needed a bit of attention - one was worn mostly on one side, the other was egg shaped. I chucked them up in the lathe and trued them up, sanded them with coarse emery cloth. Now they looked like go-kart slicks. Figured why not groove them? Cut them with a boring bar, cleaned up the cuts with the tip of a #3 centerdrill by hand... I call them "Wee- treads"... The rubber actually cut just fine - in the past I have had to put rubber parts in the freezer for at least 2 hours before I could get a clean cut. Edited February 7, 2023 by ri702bill 7 6 Share this post Link to post Share on other sites
CCW 1,519 #2 Posted February 7, 2023 I do miss my access to the lathe and miller in my last metals lab. 1 Share this post Link to post Share on other sites
ri702bill 13,084 #3 Posted February 7, 2023 1 minute ago, CCW said: I do miss my access to the lathe and miller in my last metals lab. ... and that is exactly why we have the lathe and the large benchtop miller here. CCW across the Big Pond is called "Anti-Clockwise" 1 Share this post Link to post Share on other sites
pacer 3,180 #4 Posted February 7, 2023 Aint a lathe a wunnerful tool?? While I can make some complicated 3-4 hour project that could only be done on a lathe - or mill - what I find Im doing most is some little 10min bushing or extra thick washer to take up some slack, etc, etc, small items that I would have to order or go to the big box. Was doing a 'pre-season' ck on my main mower D200 other rainey, cold day and spotted the steering wheel knob/spinner was missing the center piece (had the logo on it). So I go over to the "stock pile" - (odds/ends of cut-offs etc) and spot a round piece of 1/1/2" brass .... 10-15 mins later I had me a nice shiney brass insert for the Knob!! 1 1 Share this post Link to post Share on other sites
ri702bill 13,084 #5 Posted February 7, 2023 6 minutes ago, pacer said: 10-15 mins later I had me a nice shiney brass insert for the Knob!! Yup, cutting and grooving these was not even a 2 beer job!! 1 Share this post Link to post Share on other sites
c-series don 12,478 #6 Posted February 7, 2023 That’s brilliant! Makes me want a lathe! 1 Share this post Link to post Share on other sites
squonk 48,141 #7 Posted February 7, 2023 (edited) Az Tractor had a bin of those wheels at the show. Like 15 bucks or so. Edited February 7, 2023 by squonk 1 Share this post Link to post Share on other sites
ri702bill 13,084 #8 Posted February 7, 2023 (edited) OK .....new, or gently used ?? Edited February 7, 2023 by ri702bill Share this post Link to post Share on other sites
Handy Don 17,484 #9 Posted February 7, 2023 54 minutes ago, squonk said: Az Tractor had a bin of those wheels at the show. Like 15 bucks or so. Yep, I bought two! 1 Share this post Link to post Share on other sites
Lee1977 7,785 #10 Posted February 11, 2023 On 2/7/2023 at 9:32 AM, ri702bill said: Yup, cutting and grooving these was not even a 2 beer job!! Careful there those things are holler. I have a couple with holes in them on my 42"deck. I was looking for something else and found two in a box that wasn't that bad. I'll drill them out to 5/8" and add some brass bushings. 2 1 Share this post Link to post Share on other sites
rick 318 #11 Posted February 11, 2023 Has anyone replaced the bushings in these wheel assemblies? Just wondering if there is a stock bushing available from Grainger or McMaster-Carr. I've never knocked one out to see, maybe someone has? Share this post Link to post Share on other sites
Lee1977 7,785 #12 Posted February 11, 2023 (edited) 11 minutes ago, rick said: Has anyone replaced the bushings in these wheel assemblies? Just wondering if there is a stock bushing available from Grainger or McMaster-Carr. I've never knocked one out to see, maybe someone has? They have splintered steel bushings, as above have drilled them out and added 5/8" OD x 1/2" ID brass bushings, They are easy to drill out, the original bushing provides little resistance. I believe they are welded in, so the hub is the bushing. The bushings can found at Tractor Supply in the drawer section if they keep them replaced. Edited February 11, 2023 by Lee1977 2 Share this post Link to post Share on other sites
