HLG 3 #1 Posted January 30, 2023 (edited) I have a very early Toro workmaster serial number 365 need info Edited January 30, 2023 by HLG 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,976 #2 Posted January 30, 2023 Welcome to Red square. See 2 possibilities with same model number and serial number. Model number 08326 1980 used Kohler K-321s Spec. No. 60357d 1990 used Kohler K-321s Spec. No. 60393 Can't make a link to these but go to https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro and do search for Workmaster. 22 results will come up. Look down the serial numbers. The first is 1990 and the second is 1980 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,976 #4 Posted January 30, 2023 Have not figured out the model years yet. Click on the picture 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,976 #5 Posted February 1, 2023 Do you happen to know the model number you have? 1 Share this post Link to post Share on other sites
HLG 3 #6 Posted February 1, 2023 The best I can tell from the very faded data plate the model number is 90022 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,976 #7 Posted February 1, 2023 Did not realize I've done some research on this before. When I did it I suspected the 1962 date was wrong but perhaps it is not. Is the engine original? and if so post all the numbers off the engine including the serial number and will keep on it. This one is the first entry and the same file. 1 Share this post Link to post Share on other sites
HLG 3 #8 Posted February 1, 2023 Thank you all for trying to help me figure out what I have. The engine is out of the buggy but am hoping it's the original. I was told that the engine was loosing power so was removed to overhaul but didn't happen. I found that the ignition points were almost closed but engine has compression with finger in spark plug hole. I haven't had a chance to check with Onan to try and verify date. Engine information : number stamped in engine block 695565 There is an Onan engine data plate pop riveted to the buggy cowling with 2 pop rivets that was originally pop riveted to an engine with 4 pop rivets. The info on it as follows : Model and specification no. CK S/656N Serial no. 72C695592 Oil capacity 6 pints As soon as I can figure out how I will post photos of it all as I have read and followed quite a lot of forums but haven't participated and I'm older and somewhat computer unsavvy. Thanks again all for the information. HLG 1 Share this post Link to post Share on other sites
