gloubigoulba 87 #26 Posted January 20, 2023 Hi, i suppose the only difference beetwin B and BA bearing is that BA has seals B-2816_IKO.pdf 1 Share this post Link to post Share on other sites
Maxwell-8 4,368 #27 Posted January 27, 2023 On 1/17/2023 at 2:13 PM, 953 nut said: @Tractorhead, @Maxwell-8, @gloubigoulba, can any of you help @backlash012 find a good source of the bearings and seals he needs? I always go to TORO, they have the seals and bearings. Bearings are pretty expensive so I bought them the second time online Share this post Link to post Share on other sites
Maxwell-8 4,368 #28 Posted January 27, 2023 On 1/17/2023 at 8:31 PM, backlash012 said: Someone knows a solution or is that still useable? I have reused axles in worst condition. Very hard to get parts here so we have to do what we can to keep these old tractors going. Here is a topic when I had 3 bad transmissions at once Share this post Link to post Share on other sites
backlash012 61 #29 Posted January 30, 2023 Thanks, a friend of mine was able to weld and mill it again. So everything is fine now. 1 Share this post Link to post Share on other sites
peter lena 9,531 #30 Posted September 25, 2023 @gloubigoulba what are you using for a lubricant ? might consider getting a gear oil that has , " CLIMBING ADDITIVES " in its make up , ensuring a lubrication reach / protection , Remember , oils can be , specific , if you ask about them , very quiet , smooth , https://www.amazon.com/Lucas-10043-80W-90-Heavy-Duty/dp/B0007ZFTOA/ref=asc_df_B0007ZFTOA/?tag=hyprod- pete Share this post Link to post Share on other sites
