Brian1045 28 #1 Posted July 21, 2009 My 1045 K241 seems to running pretty well. But when I venture onto a little rougher terrain or a bumpy yard the engine wants to "cut-out" a little or throw out a small back-fire. As soon as I hit smooth ground again...everything is fine. I can even rock the tractor back and fourth at a stand still and it will do the same thing. I checked all the wires and connections, nothing is loose or grounding out. But it doesn't seem like an electrical related miss anyhow. It's more like a sputter. Could it be fuel related?? Anyone had a similar issue like this one? Any suggestions would be appreciated. :thumbs2: Share this post Link to post Share on other sites
W9JAB 156 #2 Posted July 21, 2009 Carb float? junk in fuel tank? the backfier leeds me to think fuel problem. :thumbs2: Share this post Link to post Share on other sites
djmil11 0 #3 Posted July 31, 2009 I had the same exact problem with a 16 horse Briggs.....rebuilt the carb and no more probs. :thumbs2: Share this post Link to post Share on other sites
Fire_rescue_18 0 #4 Posted August 2, 2009 I live in Gosport and had the exact same problem! Is this the same tractor that you wee havig fuel pump problems with on an older post? If so, put a clear see-thru fuel filter on it and see if its running out of gas by looking at the filter when it starts sputtering. I put a LOW VOLUME 4-6 psi electric pump on mine and it has not sputtered the first time!! Back firing is almost always fuel related. If I can help or you want to discuss it on the phone let me know. (812)821-8020 Share this post Link to post Share on other sites
Brian1045 28 #5 Posted August 2, 2009 I guess I should clarify...It's not really a back fire so to speak. It's more like a sputter or a hesitation like miss as soon as I hit a rough area in the yard or a bump. The carb has been rebuilt along with the engine just a few months ago. I may need check the float height. I have an inline filter and a glass sediment bowl. I'll check the flow tomorrow. Thanks for all of the responses ...I'll keep tinkering away. :thumbs2: Share this post Link to post Share on other sites
