Tonytoro416 1,372 #26 Posted January 5, 2023 Where the lawn rangers a short frame or wheel base ? Share this post Link to post Share on other sites
Tonytoro416 1,372 #27 Posted January 5, 2023 So I did some measuring tonight and I’m thinking the frame has been swapped. Wheel base on that tractor is 41 inches I believe the frame matches the hood stand. I think it has a lawn ranger frame and hood stand. Kinda of disheartening but really doesn’t matter. Probably going to put correct frame under it Wonder what hood I found. ? 1 Share this post Link to post Share on other sites
WHX?? 57,470 #28 Posted January 6, 2023 Not even close to being the correct hood stand. The more I look at yer pics Tony the more I for even thinking about taking on a project of this multitude. Take plenty of pics this is one for the ages... and the cover of LAGT magazine. We're here you need stuff. 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #29 Posted January 6, 2023 1 hour ago, Tonytoro416 said: Kinda of disheartening but really doesn’t matter Don't even sweat it. You got you a true gem there. Like Jimbo says, take plenty o pics. A walk around video would also be a good idea. You got all the parts from him n Kev, and all the knowhow you'll ever need around here. Share this post Link to post Share on other sites
Tonytoro416 1,372 #30 Posted January 6, 2023 (edited) 2 hours ago, WHX?? said: Not even close to being the correct hood stand. The more I look at yer pics Tony the more I for even thinking about taking on a project of this multitude. Take plenty of pics this is one for the ages... and the cover of LAGT magazine. We're here you need stuff. Yea I knew the hood stand wasn’t correct and the frame goes with the hood stand. Everything else is right. I’ll need a different hood. But it’s a true survivor. Like my story said my grandpa pulled it out of the burnt building with one thought in mind and that was making it work for what he needed. That he accomplished. It’s tilled an incredible amount of ground for being through a fire Edited January 6, 2023 by Tonytoro416 1 Share this post Link to post Share on other sites
Pullstart 70,768 #31 Posted January 6, 2023 If you feel like a drive before October, I have that hood, hood stand, frame, etc. I hear the dinner triangle jingling! com’n get it! 3 Share this post Link to post Share on other sites
ebinmaine 79,740 #32 Posted January 6, 2023 7 hours ago, Tonytoro416 said: one thought in mind and that was making it work for what he needed. That he accomplished THAT is the reason why the tractor deserves to be restored. It was built. It did a job. A great job. Many years. 7 hours ago, Tonytoro416 said: my grandpa THAT'S the reason why YOU should do the restoration. AWESOME story. An excellent piece of American History. A small piece, yes. Of a few families. Making their own place. 1 2 Share this post Link to post Share on other sites
Handy Don 16,974 #33 Posted January 6, 2023 13 hours ago, Tonytoro416 said: Yea I knew the hood stand wasn’t correct and the frame goes with the hood stand. Everything else is right. I’ll need a different hood. But it’s a true survivor. Like my story said my grandpa pulled it out of the burnt building with one thought in mind and that was making it work for what he needed. That he accomplished. It’s tilled an incredible amount of ground for being through a fire Amazing how it’s possible to mix & match WH components across so many years to just get the job done! Share this post Link to post Share on other sites
Lee1977 7,710 #34 Posted January 6, 2023 Pullstart has all the correct parts. Your rear fender is defiantly off a Lawn Ranger. Share this post Link to post Share on other sites
oliver2-44 11,632 #35 Posted January 8, 2023 On 1/5/2023 at 4:34 AM, Tonytoro416 said: My 1945 Wisconsin ADH is rated 3.9Hp@2600 RPM. It looks similar in size, but their hard to tell by size. It has a 2.750 bore and 3-1/4" stroke. So about the bore of a 7 hp K161 but the stroke of a 16 hp K341. Wisconsin doesn't list compression numbers, but I'm told my engine runs about 60-65psi, low by todays standard. Some of the Gibson "D" tractors used the ADH engine. The table below gives specs on a lot of Wisconsin engines. 1 1 Share this post Link to post Share on other sites
WHGuy413 2,859 #36 Posted January 8, 2023 What a great story. It’s great seeing tractors that have progressed throughout a family over the years. I look forward to following your progress on it. 2 Share this post Link to post Share on other sites
Tonytoro416 1,372 #37 Posted January 8, 2023 11 hours ago, oliver2-44 said: My 1945 Wisconsin ADH is rated 3.9Hp@2600 RPM. It looks similar in size, but their hard to tell by size. It has a 2.750 bore and 3-1/4" stroke. So about the bore of a 7 hp K161 but the stroke of a 16 hp K341. Wisconsin doesn't list compression numbers, but I'm told my engine runs about 60-65psi, low by todays standard. Some of the Gibson "D" tractors used the ADH engine. The table below gives specs on a lot of Wisconsin engines. This is awesome. Thank you 2 Share this post Link to post Share on other sites
Tonytoro416 1,372 #38 Posted January 8, 2023 Dad and I worked on the raider today a little bit after picking up a roller 1077. (Couldn’t pass on it for $50). We split the frame and rear end. Also got the tiller off 4 Share this post Link to post Share on other sites
Tonytoro416 1,372 #39 Posted January 8, 2023 Also we could use some help on what fenders belong on this tractor. Are they like other raiders or c series? The fenders on the 1077 I just picked up and fenders on the 1077 I already have are the same as the ones that were on this tractor. But have been told on here they aren’t correct Share this post Link to post Share on other sites
ebinmaine 79,740 #40 Posted January 10, 2023 On 1/8/2023 at 5:07 PM, Tonytoro416 said: Also we could use some help on what fenders belong on this tractor. Are they like other raiders or c series? The fenders on the 1077 I just picked up and fenders on the 1077 I already have are the same as the ones that were on this tractor. But have been told on here they aren’t correct. Maybe the pics are misleading by the angles? The rear fender for ALL the mid to late 60s except LR and GT14 were the same. Share this post Link to post Share on other sites
Tonytoro416 1,372 #41 Posted January 10, 2023 3 minutes ago, ebinmaine said: Maybe the pics are misleading by the angles? The rear fender for ALL the mid to late 60s except LR and GT14 were the same. That’s what I was thinking also. Going to use frame and hood from the 1077 I got cheap this weekend 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #42 Posted January 10, 2023 2 minutes ago, Tonytoro416 said: That’s what I was thinking also. Going to use frame and hood from the 1077 I got cheap this weekend Double check all your lineups in a correct bolted together mockup before tossing paint. Just to be sure... 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #43 Posted January 15, 2023 (edited) Been tearing apart the donor tractor so been a little slow as far as showing progress. ready to start cleaning up parts and start putting it back together Also spent some time sanding and priming a mid mount grader blade I scored on here last week Edited January 15, 2023 by Tonytoro416 2 3 Share this post Link to post Share on other sites
Pullstart 70,768 #44 Posted January 16, 2023 @Tonytoro416 was that the grader in Kalamazoo? Shoulda come up for a visit if you were that close! 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #45 Posted January 16, 2023 It was and I thought of that I really did but I just haven’t had the time. Starting to fill up with fertilizer at work in preparation for spring so haven’t been able to break away 1 Share this post Link to post Share on other sites
Tonytoro416 1,372 #46 Posted January 16, 2023 He shipped me the grader thankfully or I definitely would have made it your way 1 Share this post Link to post Share on other sites
WHX?? 57,470 #47 Posted January 16, 2023 (edited) He is a half @$$Ed cook Tony. Don't let him cajole you into pushing a broom in his shop tho... unless you need 10mm sockets... Edited January 16, 2023 by WHX?? 3 Share this post Link to post Share on other sites
Pullstart 70,768 #48 Posted January 16, 2023 You know of a piece of meat? I can smoke it! Traeger to the rescue! Share this post Link to post Share on other sites
Sailman 1,307 #50 Posted January 23, 2023 Might be off topic here but did you give any thought to a reinforcement plate on that frame where the transmission bolts to it? There are some great mods for that here on Red Square. Might be worth it while its easy to do with frame off. I have a cracked frame on one of my C-120's that was used for plowing and push blade. Project for me this spring. Just a thought. 1 Share this post Link to post Share on other sites
