benjiboo 174 #1 Posted December 19, 2022 So on my K91 Kohler that came on my Suburban 400 I had noticed a little bit of oil bubbling between the head and block. Yummy....this means a head gasket/head work needed. So I pulled the head off and the head gasket actually looked like new without any burn through or anything like that. But....the head obviously hadn't been planed prior to replacing the gasket so...here are a few pictures of my process from beginning to the end result. 2 Share this post Link to post Share on other sites
benjiboo 174 #2 Posted December 19, 2022 This picture shows just how "out of flat" a head can get and the need to plane or "reflatten" the head when replacing the head gasket. 6 Share this post Link to post Share on other sites
benjiboo 174 #3 Posted December 19, 2022 A few pictures of the condition of the block deck and cylinder bore. 3 1 Share this post Link to post Share on other sites
benjiboo 174 #4 Posted December 19, 2022 Here are the rest of the pictures of planning the head and the end result. 5 2 Share this post Link to post Share on other sites
benjiboo 174 #5 Posted December 19, 2022 (edited) Deleted Edited December 19, 2022 by benjiboo Delete 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #6 Posted December 19, 2022 And don't forget to retorque after a few heat/cool cycles! 4 Share this post Link to post Share on other sites
benjiboo 174 #7 Posted December 19, 2022 5 minutes ago, Jeff-C175 said: And don't forget to retorque after a few heat/cool cycles! Yes, this is absolutely correct. 🙂 1 Share this post Link to post Share on other sites
ri702bill 13,316 #8 Posted December 19, 2022 1 hour ago, Jeff-C175 said: And don't forget to retorque after a few heat/cool cycles! BUT - before that - you still need to do the tried and true fine sandpaper on a FLAT surface, done in a figure 8 motion. This is needed to remove the milling cutter swirl marks, and it leaves a suitable sealing surface that has random micro scratches. If you were to dust a light coat of black primer on the milled surface - one pass on the sandpaper would show that more work is needed. And yes - retorque it before working it too hard.... Bill 1 1 Share this post Link to post Share on other sites
WHX?? 58,347 #9 Posted December 19, 2022 I hate glassing heads... requires patience which I have none of. I do mist them abit with paint and when the paint is gone good to go. Not worried about raising the compression Ben? 2 Share this post Link to post Share on other sites
benjiboo 174 #10 Posted December 20, 2022 8 minutes ago, WHX?? said: I hate glassing heads... requires patience which I have none of. I do mist them abit with paint and when the paint is gone good to go. Not worried about raising the compression Ben? Not enough to be an issue. I'm not sure exactly what the compression ratio of a K91 is supposed to be after doing a quick search, but skimming a few .001" off isn't going to hurt anything. If anything it'd probably give this old engine a little more spring in it's step. The manufacturer calls for 86 octane or higher so it's definitely not a high compression engine from the beginning. Some may want to go on about timing issues and such blah blah blah but on this engine it's not going to make any real notable difference. If one was to really mill the head down then yes eventually you'd run into issues with high compression...but what I've done is no different than the sand paper and piece of glass technique, I've just done it how it's done at the factory with a mill. 2 4 Share this post Link to post Share on other sites
benjiboo 174 #11 Posted December 20, 2022 26 minutes ago, ri702bill said: BUT - before that - you still need to do the tried and true fine sandpaper on a FLAT surface, done in a figure 8 motion. This is needed to remove the milling cutter swirl marks, and it leaves a suitable sealing surface that has random micro scratches. If you were to dust a light coat of black primer on the milled surface - one pass on the sandpaper would show that more work is needed. And yes - retorque it before working it too hard.... Bill Not really...I'm pretty sure the heads are milled flat after casting when they're new. The sand paper trick wouldn't hurt anything but it's really not necessary, it'll seal up just fine after milling. 1 1 Share this post Link to post Share on other sites
WHX?? 58,347 #12 Posted December 20, 2022 4 minutes ago, benjiboo said: The sand paper trick wouldn't hurt anything but it's really not necessary, it'll seal up just fine after milling. I would guess so if the mill tool is right and speed right. Share this post Link to post Share on other sites
953 nut 70,325 #13 Posted December 20, 2022 12 hours ago, benjiboo said: I'm not sure exactly what the compression ratio of a K91 is supposed to be after doing a quick search, but skimming a few .001" off isn't going to hurt anything. It was 6.6 to 1 coming off the assembly line, bet you have kicked it up to 6.600001 to 1. 12 hours ago, benjiboo said: Some may want to go on about timing issues and such blah blah blah but on this engine it's not going to make any real notable difference. Probably not too much of a high performance issue but the timing needs to be spot on if you want it to start well. 1 1 Share this post Link to post Share on other sites
ri702bill 13,316 #14 Posted December 20, 2022 13 hours ago, benjiboo said: Not really...I'm pretty sure the heads are milled flat after casting when they're new. The sand paper trick wouldn't hurt anything but it's really not necessary, it'll seal up just fine after milling. Curious on this one - please continue the post after there are quite a few hours of use - be nice to know it the step I recommended is, or is not necessary for a longterm repair.... Bill Share this post Link to post Share on other sites
benjiboo 174 #15 Posted December 20, 2022 2 hours ago, ri702bill said: Curious on this one - please continue the post after there are quite a few hours of use - be nice to know it the step I recommended is, or is not necessary for a longterm repair.... Bill 2 hours ago, ri702bill said: Curious on this one - please continue the post after there are quite a few hours of use - be nice to know it the step I recommended is, or is not necessary for a longterm repair.... So basically my point about this part was that they don't have people in the factory with glass and sandpaper planing out heads...they're mass produced and after casting are probably either milled or knocked flat on a belt sander and slapped together. Lol. I'm not saying your method is wrong or doesn't yield excellent results, as I've done it myself that way in the past and it worked great. If we were working on really high compression, high revving race engines then I'd agree a little more attention to detail would probably be in order. My thought process was do it as close to the manufacturing process and it should be sufficient since they, by in large, operate trouble free that way for years from the factory. When we tighten down these heads they deform and deflect a little anyway so as soon as you torque the bolts down, it's no longer perfectly flat anyway. So at some point we end up unnecessarily chasing our own tails if we over complicate it. Lol. I would say most head gasket replacement failures are a result of an improper torque process if the head is satisfactorily flat. As for the heat cycling and then retorque....well...not a bad idea one would think, but is that a recommendation from Kohler on a new engine? I don't have a definite answer for that but one wouldn't think so either however I definitely could be wrong on that part...🙂 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #16 Posted December 20, 2022 1 minute ago, benjiboo said: is that a recommendation from Kohler on a new engine? I don't have a definite answer for that but one wouldn't think so either Run it a few times, then put the torque wrench on it and check it. You will be surprised at how loose the head bolts have become! That should be the answer right there I think? Share this post Link to post Share on other sites
benjiboo 174 #17 Posted December 20, 2022 2 minutes ago, Jeff-C175 said: Run it a few times, then put the torque wrench on it and check it. You will be surprised at how loose the head bolts have become! That should be the answer right there I think? Yeah probably not a bad idea one would think. 🙂 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #18 Posted December 20, 2022 2 minutes ago, Jeff-C175 said: Run it a few times, then put the torque wrench on it and check it. You will be surprised at how loose the head bolts have become! That should be the answer right there I think? Most of the time I torque mine when the engine is warm, as well. NOT HOT... just warm. Don Share this post Link to post Share on other sites
Jeff-C175 7,211 #19 Posted December 20, 2022 4 hours ago, Snoopy11 said: Most of the time I torque mine when the engine is warm, as well. NOT HOT... just warm. Don I usually wait till it cools again. But 'warm' is a relative term! I don't usually torque heads when the wind chill is -25 ! 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,998 #20 Posted December 21, 2022 Doesn't hurt to replace head bolts either.Although Some may say....relax, its a lawn mower not the Space shuttle! 3 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #21 Posted December 21, 2022 31 minutes ago, Wheelhorse#1 said: Doesn't hurt to replace head bolts either.Although Some may say....relax, its a lawn mower not the Space shuttle! Depends on the bolt, I really like to try and find Grade 8 serrated flange head bolts when I can find the right length, but as long as they haven't been over torqued, older head bolts don't "wear". 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #22 Posted December 21, 2022 (edited) 2 hours ago, RED-Z06 said: serrated I think serrated is a mistake Tom. Edited December 21, 2022 by Jeff-C175 Share this post Link to post Share on other sites
RED-Z06 2,720 #23 Posted December 21, 2022 25 minutes ago, Jeff-C175 said: I think serrated is a mistake Tom. Not a fan of serrated? I like how they really bite the head. Head really shouldnt be something you remove often, 500 hours or so. Haven't noticed any problems with the torque wrench on them, but i don't use them often...maybe a dozen engines that kept having loose head bolts with new oem hardware torqued to spec. Share this post Link to post Share on other sites
Jeff-C175 7,211 #24 Posted December 21, 2022 20 minutes ago, RED-Z06 said: Not a fan of serrated? No... I'd be afraid they would chew up the aluminum head. But the K series have a steel washer under them so that shouldn't be an issue. Wouldn't use them without a washer on aluminum though. Share this post Link to post Share on other sites
WHX?? 58,347 #25 Posted December 21, 2022 10 hours ago, RED-Z06 said: head bolts don't "wear". They say they can "stretch". While we're on the subject lube or anti-sieze them? 1 Share this post Link to post Share on other sites
