Vintner 17 #1 Posted December 19, 2022 I have a 1984 WH 310. I replaced the battery last spring, but it's not being charged. Is there a thread here that will walk me through finding the problem? TIA 2 Share this post Link to post Share on other sites
oliver2-44 11,758 #2 Posted December 19, 2022 Download the Kohler manual from the Manual Section on here. There is a good section on all the Kohler electrical. Also download the manual for you tractor and see the wiring diagram for it. 2 Share this post Link to post Share on other sites
Jeff-C175 7,211 #3 Posted December 19, 2022 (edited) First question should be, do you own and know how to use a multimeter? @Vintner Edited December 19, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
pfrederi 21,176 #4 Posted December 19, 2022 First year for 310 was 1985 I believe. Do you have a model number? If it is 1985 310 it had the 3 amp unregulated system. 1 1 Share this post Link to post Share on other sites
Vintner 17 #5 Posted December 20, 2022 Thank you all for your replies. I have never been able to find a model number on the tractor. I'm pretty sure it's an 84 from the model number on the engine. I will try your suggestions and come back if I still can't figure it out. Thanks again! 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #6 Posted December 20, 2022 @Vintner... you may be interested only in fixing your current system. I completely respect that and many of us (myself included) who have encountered this system are here to help. Having said that, there are options for you if you need a new charging system, including a relatively inexpensive upgrade to a 15 amp charging system. Regards, Don 1 Share this post Link to post Share on other sites
peter lena 10,076 #7 Posted December 21, 2022 @Vintner totally agree with @Snoopy11 on the OPPORTUNITY to upgrade and eliminate your charging issue , that 15 amp upgrade is the way to go , love making a chronic problem , go away , and make it an example of what it can be , you are right there , why not ? tesla , pete 1 Share this post Link to post Share on other sites
pfrederi 21,176 #8 Posted December 21, 2022 The 3 amp system on my 310-8 works just fine. I would agree only if testing reveals your stator is bad then it would be worth the $$ for the upgrade. 1 Share this post Link to post Share on other sites
Rob R 989 #9 Posted December 21, 2022 A simple thing you can do and what solved my 310-charging issue was to simply remove the rectifier and clean and sand the back of the unit and the place where it mounts (especially if the tractor has been repainted). You have to have excellent grounding for the charging circuit to work. 1 Share this post Link to post Share on other sites
peter lena 10,076 #10 Posted December 21, 2022 @Vintner note the 3 rd picture down , that added ground cable , coming from battery ground bolt spot to , lower corner of engine frame area , next to clutch pedal , enhanced engine grounding to rectifier , had that issue on my 3 horses, problem gone , pete 1 Share this post Link to post Share on other sites
