ri702bill 11,140 #1 Posted December 10, 2022 (edited) Per my previous post, the rear weights are assembled, but it was evident a device was needed to hold the weight securely while lineing it up to the wheel. I make a simple bolt on attachment for my trusty 40 year old 2 ton floor jack. Most of it was made from various itens from the "Parts Department". A length of 2-14" OD exhaust pipe, a pair of two 2-1/2" conduit clamps, a pair of 1/8" x 1" flat straps drilled for the clamps, and a short length of 5/16" threaded rod, inserted thru the end of the pipe to act as a stop to keep the weight in place. Worked well. Total cost was under $15 bucks. Edited December 10, 2022 by ri702bill 2 15 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #2 Posted December 10, 2022 That is slick 2 Share this post Link to post Share on other sites
ri702bill 11,140 #3 Posted December 10, 2022 No, 30 weight is slick!! Thanks for the comment, This was needed to avoid the juggling act and the pinched fingers. Hope others agree... My biggest fear was that the jack would tip forward with the weight on - another 6" overhang and it would. Bill 2 Share this post Link to post Share on other sites
pfrederi 19,794 #5 Posted December 10, 2022 Nice!!! 1 Share this post Link to post Share on other sites
ri702bill 11,140 #6 Posted December 10, 2022 All - feel free to take this design and alter as needed for your own application - seems that the older floor jacks had the larger saddle plate - my newer 3 ton has a much smaller plate, about the size of a hockey puck... 2 Share this post Link to post Share on other sites
peter lena 9,710 #7 Posted December 10, 2022 @ri702bill thats what i,m talking about , adapting to a problem , lots of tractor related areas is , leverage advantage . put some screw in wood 2 " swivel rings , for a 500 lb lever chain hoist , 3ft nylon lift strap , get it close to tractor , makes things easy , pete 2 Share this post Link to post Share on other sites
peter lena 9,710 #8 Posted December 10, 2022 @ RI702 BILL ,https://www.hardwareandtools.com/national-hardware-n220-640-s120-089-hitching-ring-on-eye-bolt-5-16-by-3-1-4-inch-2-inch-ring-zinc-plated-steel-ueab-1658.html installed these in my lift areas , for that small chain hoist , also use these to hold my mower decks in place against the wall , bent up some 5/16 steel round rod for a hook to grab the mower deck lift carriage, always making easier for the next time , pete 2 Share this post Link to post Share on other sites
peter lena 9,710 #9 Posted December 10, 2022 @ri702bill attach the grab hook to a strong extension spring , eye bolt , that deck is not going any ware , hooked up , pete 2 Share this post Link to post Share on other sites
ri702bill 11,140 #10 Posted December 10, 2022 @peter lena I have my 2 decks propped up against the back wall of the garage using a tire chock ...! Might take your advise so I can get my chock back over the winter. Bill 2 Share this post Link to post Share on other sites
CCW 1,467 #11 Posted December 10, 2022 I love tool hacks. 2 Share this post Link to post Share on other sites
WHX?? 54,527 #12 Posted December 10, 2022 My back thanks you! 1 1 Share this post Link to post Share on other sites
peter lena 9,710 #13 Posted December 10, 2022 @WHX?? as I get older , just can't handle the heavy awkward deck lift like I used to . found that small chain lift , with a wide wire hook attached , to front wheel on deck , easily controls it into space , then I use an extension spring from wall to hold it in place on carriage lift of deck , makes it much easier , pete 2 Share this post Link to post Share on other sites
953 nut 63,969 #14 Posted December 10, 2022 5 hours ago, ri702bill said: biggest fear was that the jack would tip forward with the weight on I attempted the same thing but my jack isn't as hefty as yours, though about adding weight to the back of the jack. It was easier to just pull the wheel off and lay it on a couple 4X4s then remount it. 3 Share this post Link to post Share on other sites
Horse Newbie 7,401 #15 Posted December 10, 2022 3 hours ago, peter lena said: use these to hold my mower decks in place against the wall , bent up some 5/16 steel round rod for a hook to grab the mower deck lift carriage, always making easier for the next time , pete I’d like to see a picture of that… 1 Share this post Link to post Share on other sites
Horse Newbie 7,401 #16 Posted December 10, 2022 22 minutes ago, peter lena said: @WHX?? as I get older , just can't handle the heavy awkward deck lift like I used to . found that small chain lift , with a wide wire hook attached , to front wheel on deck , easily controls it into space , then I use an extension spring from wall to hold it in place on carriage lift of deck , makes it much easier , pete How about a pic of that set up ? 1 Share this post Link to post Share on other sites
Horse Newbie 7,401 #17 Posted December 10, 2022 6 hours ago, ri702bill said: Per my previous post, the rear weights are assembled, but it was evident a device was needed to hold the weight securely while lineing it up to the wheel. I make a simple bolt on attachment for my trusty 40 year old 2 ton floor jack. Most of it was made from various itens from the "Parts Department". A length of 2-14" OD exhaust pipe, a pair of two 2-1/2" conduit clamps, a pair of 1/8" x 1" flat straps drilled for the clamps, and a short length of 5/16" threaded rod, inserted thru the end of the pipe to act as a stop to keep the weight in place. Worked well. Total cost was under $15 bucks. What brand is that 40 year old jack ? 1 Share this post Link to post Share on other sites
ri702bill 11,140 #18 Posted December 10, 2022 Sears Craftsman - USA made AND rebuildable (already did) The 3 ton - same brand - made somewhere else - when it dies, it goes. 1 Share this post Link to post Share on other sites
WHX?? 54,527 #19 Posted December 11, 2022 (edited) 59 minutes ago, 953 nut said: It was easier to just pull the wheel off and lay it on a couple 4X4s then remount it. I'm not seeing that Richard... most WWs cover the mounting studs? Guessing that would be really hard if tires are loaded? Edited December 11, 2022 by WHX?? Share this post Link to post Share on other sites
Horse Newbie 7,401 #20 Posted December 11, 2022 2 hours ago, ri702bill said: Sears Craftsman - USA made AND rebuildable (already I was asking because a friend of mine has an old Craftsman floor jack(circa1980) … great jack… can’t get ‘em new like that anymore… 1 Share this post Link to post Share on other sites
