hodge
8 lug rims
hodge
I have a 94 Dodge 2500, and would like to pick up a second set of rims/tires. Does anyone on here know of the top of their head what other manufacturers will fit? I don't think all 8 lugs are the same, but I would imagine that some are. Thanks!
Nick
You can search local salvage yard for used rims through this site. http://car-part.com/ An older ford might work but I know in 99 Ford 8 lug wheels went to a new bolt pattern.
hodge
Thanks, Nick. I have this question on a Dodge forum, and just received the info that pre-99 Fords will fit.
Nick
I thought the Fords might fit but wasnt sure. You might try craigs list for a deal on some used tires/tims. I like to use http://www.searchtempest.com/
KyBlue
Your dodge is a 8 on 6.5" bolt pattern, the 99 up fords are 8 on 135mm pattern I think...
All the 8 lugs are the same, the older ones anyhow, Fords, Chevy's, Dodges,
Kelly
Yes all older ones are the same bolt patern,but the center hole is diff. make sure you check that.
hodge
Thanks, you guys. As always, a blessing and a wealth of knowledge.
Now, to find some, and the money to buy them...
baerpath
The older Chevy/GMC rims just need the center hole opened up a little to fit. We just used a stone on a drill on ours. Didn't take much.
Duane
