peter lena 9,315 #1 Posted November 24, 2022 https://www.amazon.com/Bearing-Bronze-Bushing-Bearings-VXB/dp/B00FN55O62 often suggest and refer to larger bearings , same size pulley type / sprockets , in addition to the larger bearing , with easily removed grease shields , for a hi temp grease upgrade , regularly use this type of bushing , a push in size to size fit , down to original 3/8 ID bolt mount . only a reference to type , local h/w PROBABLY HAS THEM IN STOCK. .the solid smooth movement difference is amazing overkill difference . it just stops a nagging problem . having done this , its just the problem answer, make your attachments run with smooth / quiet , ease . turkey grease, pete 3 1 Share this post Link to post Share on other sites
sjoemie himself 3,099 #2 Posted November 26, 2022 Hey mr. greasy @peter lena might I add a suggestion for all your greasing/lubrification tips and tricks? Besides adding your tips and tricks in all kinds of topics and in topics such as this one.. would'nt it be much more clear to 'bundle' all your lubrication and improvement tips and tricks into one topic? Something like "lubrication and improvements by greasy pete".. that way people can easily search all kinds of lubricating and improvement solutions in one topic and all your knowledge doesn't 'go to waste' in between all the other talk. @mods/admins? 1 Share this post Link to post Share on other sites
peter lena 9,315 #3 Posted November 26, 2022 @sjoemie himself thank you for the suggestion , I can relate to multiple searches and look around areas, not sure how I would do it . would that , @ mods/admins ? be a possible start ? not a computer / internet geek , so it would be a search . example was just snooping around on the horse and made another improving change on plow lift . see what I can do , thanks pete Share this post Link to post Share on other sites
peter lena 9,315 #4 Posted December 1, 2022 @sjoemie himself https://www.wheelhorseforum.com/discover/content-started/?&before=1661259722&latest=1652614905 , concentration of a number of ideas that I use , pete Share this post Link to post Share on other sites
