Ed Kennell 44,823 #1 Posted November 21, 2022 Does anyone have a good source for a shaft seal for a 953 hydraulic pump. The part number is 1477. I measure it at 1/2" ID x 11/16" OD x 1/8" wide. I did find a Bolens #1722038 is a replacement. 1 Share this post Link to post Share on other sites
stevasaurus 23,609 #2 Posted November 21, 2022 Might check with @Lane Ranger. 1 Share this post Link to post Share on other sites
Achto 30,957 #3 Posted November 21, 2022 (edited) 1 hour ago, Ed Kennell said: Does anyone have a good source for a shaft seal for a 953 hydraulic pump. , early Scrub Cadet, Jacobsen & Bolens all used the same Hein Werner pumps. Lowell carries parts & complete rebuild kits for these pumps. Might need to give him a call if all you need is the shaft seal. https://wheelhorsepartsandmore.com/product/cub-cadet-bolens-ford-jacobsen-hein-werner-hydraulic-pump-seal-kit/ Edited November 21, 2022 by Achto 1 1 Share this post Link to post Share on other sites
Lane Ranger 11,778 #4 Posted November 22, 2022 (edited) 13 hours ago, Ed Kennell said: Does anyone have a good source for a shaft seal for a 953 hydraulic pump. The part number is 1477. I measure it at 1/2" ID x 11/16" OD x 1/8" wide. I did find a Bolens #1722038 is a replacement. Ed the original shaft seal for the Hein Werner pump was a little thicker than the remake replacements that are out there. I had a few of the originals but have sold all of them over the years. one of the issues with the shaft is the wear on the actual shaft from turning. The newer seals are thinner. One of the things that can be done is to place two seals in the shaft space. There is just enough room for the rubber on the second seal to fit in-the depressed area. I have often purchased Hein Werner parts from Cub Cadet, Bolens and other tractor suppliers for the pumps as they may have other numbers of the part but the pumps and parts are the same! Edited November 22, 2022 by Lane Ranger 2 1 Share this post Link to post Share on other sites
