nak8111 2 #1 Posted November 14, 2022 Has anybody fund replacement bearing for this snow blower. The OEM bearing hs a horriboe price tag. I know there has to be alternatives available Thanx a milliion nak8111 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #2 Posted November 14, 2022 Which bearing? https://www.partstree.com/models/06-42st04-toro-42-snow-thrower-attachment-1984/snowthrower-42-in-107-cm-vehicle-identification-numbers-06-42st04-06-42sy02-1/ 1 Share this post Link to post Share on other sites
peter lena 10,013 #3 Posted November 16, 2022 @nak8111 you are not specific on the bearing , personal experience , is the lubricant failure in related bearings , if you are dealing with a wide rubber side shield on the bearing , you could easily / carefully remove the shields , wipe out / flush out existing grease , use a hi temp grease , 560 deg , lucas marine grease and, or x tra hd , polyurea / anti sling , will make a bearing fail safe . done this to all my related w/h attachments with whining / rough bearings . my 42 st01 , spins up without effort or noise . look at your problem as an opportunity . pete 1 Share this post Link to post Share on other sites
peter lena 10,013 #4 Posted November 16, 2022 @nak8111 not the same bearing / pulley related ,but the same issue , make a problem go away , pete 1 Share this post Link to post Share on other sites
nak8111 2 #5 Posted November 17, 2022 Sorry for the confusion. I need the Lutco Bearing driving the chain . Toro # 10744 which "is no longer available" Thanx for the help 1 Share this post Link to post Share on other sites
peter lena 10,013 #6 Posted November 17, 2022 @nak8111 add this to your look up , https://www.bing.com/images/search?q=10744 bearing %2C wheel horse snow blower&qs=n&form=QBIR&sp=-1&pq=10744 bearing %2C wheel horse snow blower&sc=0-39&cvid=DECF78E6D7CB403B8C899506EFF450AA&ghsh=0&ghacc=0&first=1&tsc=ImageHoverTitle has to be a similar bearing here , pete 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #7 Posted November 17, 2022 (edited) On 11/14/2022 at 4:50 PM, nak8111 said: alternatives I replaced mine with these: https://thebigbearingstore.com/3-4-two-bolt-flange-bearing-ucfl204-12/ Of course it meant a little bit of modification (drilling holes), and I also needed a new shaft because it was REALLY rusted, and turns out that the replacement bearings needed a slightly longer shaft. https://thebigbearingstore.com/3-4-x-36-keyed-shaft/ I'm not sure if your shaft is 3/4" though, but they have other sizes at "The Big Bearing Store". (I have no interest in them other than I'm a satisfied customer) Here's the thread with my 'saga'. Edited November 17, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
