tractorhogg 656 #1 Posted November 13, 2022 Can anyone show pictures of how the PTO clutch brake is installed ion the Kohler D series singles, I'm stumped. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #2 Posted November 13, 2022 Do you have the 1978-79 B,C and D-Series service manual? Section 9 has the pto. https://www.partstree.com/models/1-0650-d-160-toro-lawn-tractor-1974/p-t-o-clutch-cont-d-12/ 1 Share this post Link to post Share on other sites
tractorhogg 656 #3 Posted November 13, 2022 2 minutes ago, gwest_ca said: Do you have the 1978-79 B,C and D-Series service manual? Section 9 has the pto. https://www.partstree.com/models/1-0650-d-160-toro-lawn-tractor-1974/p-t-o-clutch-cont-d-12/ I do have that manual, I could not see how it bolts on and what part the brake rubs against Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #4 Posted November 13, 2022 Found this in the 1975 operator manual 2 Share this post Link to post Share on other sites
tractorhogg 656 #5 Posted November 14, 2022 24 minutes ago, gwest_ca said: Found this in the 1975 operator manual I have that picture in the service manual, but that is a Kohler 18 hp-20 hp 482s or 532s. Here is the clutch brake and my clutch. I bought the brake from a member here and it was a reproduction, but it looks like others I have seen. I don't see how it can attach and work unless I drill the rivets and put the pad on the other side or cut off the slots and re drill them closer, Check out my pictures Share this post Link to post Share on other sites
tractorhogg 656 #6 Posted November 14, 2022 I bought this part from a member here, and the only way I could see that it would work is if I cut off the long end with the slots and made new slots closer to the brake lining Share this post Link to post Share on other sites
