Jeff-C175 7,211 #26 Posted November 12, 2022 (edited) 37 minutes ago, Brockport Bill said: Yes And this plug is not installed on the Series I. Not drilled through. I think that's for an oil pressure switch? Edited November 12, 2022 by Jeff-C175 2 Share this post Link to post Share on other sites
Brockport Bill 2,455 #27 Posted November 12, 2022 15 minutes ago, Achto said: Yep, that's what I use. Just make sure that you have any rubber seals removed from the carb, cause it will dissolve them. https://www.autozone.com/fuel-and-engine-cleaners-additives/carburetor-and-throttle-body-cleaner/p/berryman-chem-dip-carburetor-parts-cleaner-96oz/139313_0_0?cmpid=LIA:US:EN:AD:NL:1000000:PER:8362741362&gclid=Cj0KCQiApb2bBhDYARIsAChHC9t5l5i8AwLur6QmXro4iyWvevofiYKL7q9uRZnKke2ZhwzV4EBbrT4aAqYZEALw_wcB&gclsrc=aw.ds Gunk also make a carb/ parts cleaner, I don't think that it is as effective as Berrymanns though. 39 dollars at local autozone -- cheaper than amazon 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #28 Posted November 12, 2022 23 minutes ago, Achto said: Gunk also make a carb/ parts cleaner, I don't think that it is as effective as Berrymanns though. I've tried many different kinds... CRC being the one I currently have. You can tell from my "eye roll emoji" ...I don't feel that it's very effective.. definitely going to pick up some B-manns and give that a whirl next time I need to clean a carb! Don 2 Share this post Link to post Share on other sites
AHS 1,698 #29 Posted November 12, 2022 The first thing I’m going to do is print a manual off here! I’ve got a bunch of Kohler K and Magnum singles, but this is the first twin I’ve ever had! 😀 1 Share this post Link to post Share on other sites
Brockport Bill 2,455 #30 Posted November 12, 2022 here is photo of my C175 Series 1 engine to differentiate from the C175 Series 2 that I posted earlier in this thread - not a great photo but shows the difference 3 Share this post Link to post Share on other sites
ebinmaine 80,297 #31 Posted November 13, 2022 2 hours ago, Snoopy11 said: What is your carb soaking liquid, there Eric? Got something special fa' 'dat? I've been looking for a good soaking liquid lately... didn't think Epsom salt was a good option... Don I've tried Berrymans and Gunk. Both work about the same as near as I can see. 1 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #32 Posted November 13, 2022 13 hours ago, Jeff-C175 said: How would a filter work on a splash lubricated engine? How would the oil be pushed through the filter? I 1 Share this post Link to post Share on other sites
AHS 1,698 #33 Posted November 14, 2022 Ok, I have that “occasional backfire at top end” from what the seller said, I trust him. I am going to replace the points, condenser, coil and clean the carb. (Or replace the carb— isavetractors has them). What do you think? Share this post Link to post Share on other sites
953 nut 68,514 #34 Posted November 14, 2022 30 minutes ago, AHS said: replace the points, condenser, I would start with the most likely suspects, a weak condenser or points are the most common culprits and should be replaced first. 2 Share this post Link to post Share on other sites
ebinmaine 80,297 #35 Posted November 14, 2022 In my opinion it would be a great idea to replace things one at a time. One. Replace Condenser. Two. Clean or replace points. Three. CLEAN carburetor. Not sure the coil is part of the equation here.... Could be. 3 Share this post Link to post Share on other sites
