AHS 1,703 #1 Posted November 12, 2022 The engine tin have “series 11”, but it has a coil. I thought the only series 11 were magnum? Is it series 1 or 11? Sorry, I couldn’t get the picture to load Share this post Link to post Share on other sites
Pullstart 71,518 #2 Posted November 12, 2022 Does it have an oil filter? That is what I’ve gathered is an easy way to tell Series 1 and 2 apart. 1 Share this post Link to post Share on other sites
ebinmaine 81,139 #3 Posted November 12, 2022 4 minutes ago, Pullstart said: Does it have an oil filter? That is what I’ve gathered is an easy way to tell Series 1 and 2 apart. Series II were built with AND without oil filters. 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #4 Posted November 12, 2022 Kt is a K-series twin cylinder Mt would be a magnum-series but that did not happen M18 was the next twin 4 1 Share this post Link to post Share on other sites
ebinmaine 81,139 #5 Posted November 12, 2022 13 minutes ago, AHS said: couldn’t get the picture to load If ya renew your supporter status you can load more pics. I took it from our text. 1 Share this post Link to post Share on other sites
Pullstart 71,518 #6 Posted November 12, 2022 4 minutes ago, ebinmaine said: Series II were built with AND without oil filters. I learned something new today! Back to bed! 4 Share this post Link to post Share on other sites
ebinmaine 81,139 #7 Posted November 12, 2022 1 minute ago, Pullstart said: I learned something new today! Back to bed! 1 Share this post Link to post Share on other sites
Pullstart 71,518 #8 Posted November 12, 2022 (edited) 20 minutes ago, AHS said: Sorry, I couldn’t get the picture to load Becoming a supporting member generally takes care of that issue. It helps the site stay alive and opens up a few cool perks for ya too! https://www.wheelhorseforum.com/store/ Edited November 12, 2022 by Pullstart 2 1 Share this post Link to post Share on other sites
AHS 1,703 #9 Posted November 12, 2022 Ok. Series 11 does have an ignition coil. Bingo! Share this post Link to post Share on other sites
edgro 680 #10 Posted November 12, 2022 417A Series II, both of mine, coil yes, oil filter no 2 Share this post Link to post Share on other sites
bds1984 1,519 #11 Posted November 12, 2022 One can add an oil filter to a Series II if the block off plate is removable. 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #12 Posted November 12, 2022 How would a filter work on a splash lubricated engine? How would the oil be pushed through the filter? 1 Share this post Link to post Share on other sites
8ntruck 9,382 #13 Posted November 12, 2022 I'm pretty sure that the KT series II engines are full pressure oil systems. The KT steries I engines had a drip oiling system for the big ends of the rods with an oil pump pumping the oil to the crankshaft journals and through the camshaft that has the 'drip ports' to distribute the oil to the rods. The series II engines added oil passages in the crank to oil the rods. 1 3 Share this post Link to post Share on other sites
Achto 32,923 #14 Posted November 12, 2022 Here is an illustration depicting the oiling differences between a Series I and a Series II 5 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #15 Posted November 12, 2022 (edited) 3 hours ago, Jeff-C175 said: How would a filter work on a splash lubricated engine? How would the oil be pushed through the filter? Hunter at ARC Racing once told me that some people run scavenge pumps on their small engines with remote, inline oil filter. (obviously, after pumping out of the engine, going through the SP, through the filter, the engine would have to be tapped somewhere for a return line). Dunno if that helps... but I have considered installing such a system in my own K341 engine... Don Edited November 12, 2022 by Snoopy11 Mehr detrails... 1 Share this post Link to post Share on other sites
AHS 1,703 #16 Posted November 12, 2022 Ok, I went this morning and got a series 2 Kohler 17 for $30!!!!!😀 it has an occasional backfire at full throttle. I’m going to adjust the valves? He said he messed with the points and cleaned the carb. I’m going to change the oil, replace points, condenser, coil and adjust the valves. 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #17 Posted November 12, 2022 Just now, AHS said: adjust the valves? Unfortunately, to adjust those they need to be ground. The tappets are not adjustable. 1 minute ago, AHS said: messed with the points Hmmm... "messed with" is not a term I would use to describe adjusting the points. Sounds like a hacker term. I would adjust them with a timing light. 2 1 Share this post Link to post Share on other sites
ebinmaine 81,139 #18 Posted November 12, 2022 18 minutes ago, AHS said: Ok, I went this morning and got a series 2 Kohler 17 for $30!!!!!😀 it has an occasional backfire at full throttle. I’m going to adjust the valves? He said he messed with the points and cleaned the carb. I’m going to change the oil, replace points, condenser, coil and adjust the valves. I'd recommend ACTUALLY cleaning the carb the right way too. Remove. SOAK. Reassemble. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #19 Posted November 12, 2022 3 minutes ago, ebinmaine said: Remove. SOAK. Reassemble. What is your carb soaking liquid, there Eric? Got something special fa' 'dat? I've been looking for a good soaking liquid lately... didn't think Epsom salt was a good option... Don 1 Share this post Link to post Share on other sites
Brockport Bill 2,518 #20 Posted November 12, 2022 i was told this design feature ( see photo ) was a distinguishing factor that indicates the kohler is Series 2 ??? Yes/no? Absent that then its supposedly Series 1 ???????? 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,518 #21 Posted November 12, 2022 there was a Youtube i saw a yr or 2 ago with Kohler 17 engine completely apart and actually showed the holes in the Series 2 crank where engine was redesigned so oil would circulate -- thats what i think i see in the diagrams shown earlier in the thread posted by ACHTO 1 1 Share this post Link to post Share on other sites
pacer 3,181 #22 Posted November 12, 2022 @Brockport Bill That 'cover' piece - or lack of - is the way I've always used to tell which is which. Cause the series 1 does not have it. 3 Share this post Link to post Share on other sites
Jeff-C175 7,211 #23 Posted November 12, 2022 1 hour ago, Snoopy11 said: carb soaking liquid I've always used Berryman's 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #24 Posted November 12, 2022 4 minutes ago, Jeff-C175 said: I've always used Berryman's Thanks, I'll pick some up next time I'm out to have on hand... Don Share this post Link to post Share on other sites
Achto 32,923 #25 Posted November 12, 2022 6 minutes ago, Jeff-C175 said: I've always used Berryman's Yep, that's what I use. Just make sure that you have any rubber seals removed from the carb, cause it will dissolve them. https://www.autozone.com/fuel-and-engine-cleaners-additives/carburetor-and-throttle-body-cleaner/p/berryman-chem-dip-carburetor-parts-cleaner-96oz/139313_0_0?cmpid=LIA:US:EN:AD:NL:1000000:PER:8362741362&gclid=Cj0KCQiApb2bBhDYARIsAChHC9t5l5i8AwLur6QmXro4iyWvevofiYKL7q9uRZnKke2ZhwzV4EBbrT4aAqYZEALw_wcB&gclsrc=aw.ds Gunk also make a carb/ parts cleaner, I don't think that it is as effective as Berrymanns though. 1 Share this post Link to post Share on other sites
