BGH 7 #1 Posted November 6, 2022 I recently acquired a D-200 from my father in law. I am planning on restoring it with my kids but I need to find new rear rims. Both are rusted out from being loaded with calcium. I haven’t been able to find any 6 lug replacements locally. Will 6 lug kubota rims fit the D series? Has anyone ever adapted the 5 lug wheels to work with with the 6 lug? Any information would be appreciated. Thanks, Ben 1 Share this post Link to post Share on other sites
8ntruck 9,254 #2 Posted November 6, 2022 to the forum. Bunch of good folks here. Whatever part on a Wheel Horse that can be broken and repaired, somebody here has probably broken and repaired it, and will be happy to supply advice. In the vendors section of the form, you will find several purveyors of Wheel Horse parts. One of them can probably help you find what you are looking for. Good chance that one of the forum members can come up with the parts too. Share this post Link to post Share on other sites
BGH 7 #3 Posted November 6, 2022 Thanks. I’ll check it out. 1 Share this post Link to post Share on other sites
Pullstart 71,174 #4 Posted November 6, 2022 In similar fashion, I’ve adapted 5 lug hubs to a 953, originally with a heavy 4 lug hub. The tires on “Hot Wheels” are 27x10.50-12 Interco Interforce for a UTV. They look very classic for a tractor, but much deeper lugs. 2 Share this post Link to post Share on other sites
BGH 7 #5 Posted November 6, 2022 Those look great! Something similar to that is what I would like for the D200. 1 Share this post Link to post Share on other sites
Pullstart 71,174 #6 Posted November 6, 2022 3 hours ago, BGH said: Those look great! Something similar to that is what I would like for the D200. These are simply C series 1-1/8” hubs and wheels, with the Interco tires on them. The axle keyway is 1/4” I believe and is cut straight through the hub. I’d imagine you can verify your axles are similar. 2 Share this post Link to post Share on other sites
BGH 7 #7 Posted November 6, 2022 I'll have to check what size the 200 axle is. Swapping out hubs might be a good option. I found a D160 for sale locally it might be worth buying if I could get it for decent price. Lots of extra parts. Just a different motor. Might be cheaper in the long run. 2 Share this post Link to post Share on other sites
pfrederi 21,100 #8 Posted November 7, 2022 D series had 1-1/8" axles. yes you can put a C series hub on there....but... D's are big and heavy. The D hub is much much beefier than a C series. I guess it depends on how hard you plan on working it. Share this post Link to post Share on other sites
Lee1977 7,756 #9 Posted November 7, 2022 The 5 lug hubs with the split tappered bushing that A-Z tractor sells would stand up to the D-series. They are not cheap but that is what I would use. Share this post Link to post Share on other sites
pacer 3,180 #10 Posted November 7, 2022 @pfrederi has a good point there, they ARE a beefy tractor (and the hubs are bit#$ to pull!!). Dont rush in, here shud be someone on here that'll get you fixed up. Share this post Link to post Share on other sites
BGH 7 #11 Posted November 7, 2022 Yeah its a big machine 1000 pounds. I think finding stock rims or others that will fit is the best move. 1 Share this post Link to post Share on other sites
Pullstart 71,174 #12 Posted November 8, 2022 2 hours ago, BGH said: Yeah its a big machine 1000 pounds. I think finding stock rims or others that will fit is the best move. The 520Xi is around the same weight and uses a 5 lug hub… but is prone to premature wear if they get loose. Share this post Link to post Share on other sites
tractorhogg 667 #13 Posted November 8, 2022 I used cast iron dexter shorty hubs and put 3.75-12 steel wheels with 5.00-12 tri-ribs on the front and IntercoInterforce 30-10 x 12 rear AG tires 3 Share this post Link to post Share on other sites
BGH 7 #14 Posted November 8, 2022 That’s a good looking machine. Thats what I want to use mine for tilling and snow blowing I also have a front blade for it. 1 Share this post Link to post Share on other sites
JoeM 10,219 #15 Posted November 8, 2022 13 hours ago, Pullstart said: The 520Xi is around the same weight and uses a 5 lug hub that would work fine. I had a D160 with a loader and it was nowhere near the power of any of my xi machines. Share this post Link to post Share on other sites
tractorhogg 667 #16 Posted November 8, 2022 6 hours ago, JoeM said: that would work fine. I had a D160 with a loader and it was nowhere near the power of any of my xi machines. Its why I got rid of my large frame Bolens 1886 with a loader, these loaders on garden tractors are just novelty toys. I still have my D series and 5-6 other big GTs but I for real work I picked up a Kubota B7100HST-D 4 x 4 with a loader and box blade 1 Share this post Link to post Share on other sites
